DIY: RX-8 B-Pillar Applique
Postby Huzer21 » Wed Oct 03, 2007 9:14
What you'll need: B Pillar Appliques (duh)
Isopropyl alcohol or similar.
A good lint free rag.
Your hands.
Time to install: Going slowly, about 15 minutes.
When I get a chance, I'll scan the Mazda instructions. Straightforward stuff if you've ever installed anything with double sided tape.
1. Clean the B-Pillar using Isopropyl alcohol and a lint free rag. Wipe off any excess alcohol.
2. Let it dry. This stuff dries fast, give it just a couple of minutes, and you'll be good to go.
3. Peel the mylar backing off the applique.
4. Reapply covering most of the applique, leaving about 1/4" of the double sided tape around the rear and bottom edges expose.
5. Once you've got it lined up on the car on all directions, press down on the portion of the applique where you have exposed the tape.
6. Remove backing from the rest of the applique.
7. The appliques will dent if you put too much pressure on them. Use your palm to secure them to the B-Pillar and remove any trapped air.
8. Clean 'em up and be happy you'll have no more finger prints/waterspots, etc on the B pillars. Nice shiny piano black!
Postby tsx_guy » Wed Oct 03, 2007 9:14
nice write up, nice results.
<div class='quotetop'>QUOTE (6i_guy @ Oct 3 2007, 07:38 PM) [url=index.php?act=findpost&pid=3224]<{POST_SNAPBACK}>[/url]</div>
nice write up, nice results.[/b]
Thanks, although I felt kinda stupid writing up a DIY about how to apply peel and stick accessories.
Abridged version:
Step 1: Clean.
Step 2: Peel.
Step 3: Apply.
so how much hp does this get you?
<div class='quotetop'>QUOTE (6i_guy @ Oct 3 2007, 07:59 PM) [url=index.php?act=findpost&pid=3234]<{POST_SNAPBACK}>[/url]</div>
so how much hp does this get you?[/b]
8, per rotor. It also helps aerodynamically, since it cuts down on drag, since it's all slick.
Postby Colombia28 » Wed Oct 03, 2007 9:14
Looks sweet! I like the fact it has "RX-8" on it.
ZoomPrincess
Postby ZoomPrincess » Wed Oct 03, 2007 9:14
such a small detail , but makes so much difference to the car. Looks sweet!
OpacRX
Postby OpacRX » Wed Oct 03, 2007 9:14
Looks nice man i need to get one. I want the one with the rotor symbol and the RX-8 inside but i cant see paying $186 for a sticker lol i'm sure i will just do what you did cost allot less and still looks really good.
Postby Huzer21 » Thu Oct 04, 2007 9:14
<div class='quotetop'>QUOTE (OpacRX @ Oct 3 2007, 11:01 PM) [url=index.php?act=findpost&pid=3299]<{POST_SNAPBACK}>[/url]</div>
Looks nice man i need to get one. I want the one with the rotor symbol and the RX-8 inside but i cant see paying $186 for a sticker lol i'm sure i will just do what you did cost allot less and still looks really good.[/b]
I felt the same as you, didn't want to fork out the extra $$ for the JDM stickers. Definitely makes a difference. So far, me likes!
