Installed: CP-e Standback II EMS
Postby chickenwafer » Thu Dec 10, 2009 9:14
roninsoldier83 wrote:Actually, most high power STI's either use an EBC or 3-port BCS primarily because the factory 2-port BCS in many cases cannot keep enough pressure away from the WGA for it to not open/bleed off boost. The 2-port design found in Subaru's works well, and helps boost come on smoothly, but it less than idea. With my stock BCS, and stock "pill" in the line, I was only able to hit about 15psi at 100% WGDC... we swapped over to a smaller "pill" in order to assist the BCS in keeping pressure away from the WGA, which resulted in being able to hit about 18.5psi at 100% WGDC. Eventually, I swapped over to a 3-port (WGA has it's own line/interrupt system), and without even maxing my WGDC's we were able to hit 20psi :D
That's the real reason STI's use EBC's/3-port BCS devices. Actually though, I would point out that the fastest stock turbo STI's in the country almost all bypass the factory BCS, and use a simple Hallman MBC ;) Nothing is more reliable or consistent IMO. Most tuners worth their salt will tell you the same thing... the only downside is you may lose out on some added "safety" features your ECU may have programmed in to save your motor, but usually a motor will cut fuel prior to cutting boost, so even those are debatable.
Just figured I would add my $.02
Thanks man, that's what I was trying to say, you just did it much better than I did, LOL.
roninsoldier83
Postby roninsoldier83 » Thu Dec 10, 2009 9:14
chickenwafer wrote:Eh, you guys just don't get it so I won't waste time trying to explain it anymore LOL. If you guys did your own tuning you would understand....
You don't NEED two different maps....adjusting boost, I can see the advantage of that (I do with an EBC) but you don't need two different maps unless you are running different fuels, which would have to pull over and re-fuel anyways so switching on the fly is pointless....
I already tried explaining but it's a bit like trying to eat a steak with a straw at this point
For most people, I would say you are 100% correct. That's exactly why you tune for load, so that if at 4250rpm if your motor is seeing XXX G/S of air from your MAF instead of whatever value it was seeing whenever it was tuned, your ECU will know the correct fueling algorithm to send the proper amount of fuel. Even tuned for only one preset boost level, as seasons/weather change, your motor is constantly seeing a different amount of air injested. Don't believe me? Log your vehicle's peak WOT GS from your MAF in both 100 degree weather and log again in 15 degree weather, fairly substantial difference. That's why we tune, so that the ECU knows how to respond when we introduce higher/lower loads while driving.
Although for someone like OCD, I can completely understand why he would want separate "maps"/boost settings, mostly just for the boost control aspect. Although you're right, he could just as easily just tune for his peak pressure, and turn down the boost without any negative repercussions. It could be argued that if he wanted to make more power at a lower boost level, he could add more timing, however, that would kind of defeat the point of turning the boost down wouldn't it? Haha. His fuel trims though should be fairly similar if they were tuned correctly, if anything, maybe a tad bit richer.
For someone like myself though, unless I wanted to switch back to 91 octane, having two maps is pointless. I can see OCD's point about detuning the car because he doesn't want his wife getting into trouble/beating on the car ect. Someone like me? My wife doesn't want anything to do with my car LOL!! I don't let anyone else drive it, and almost never take my car to a place where there is valet available haha.
Wanting to detune your car because someone else you don't trust to drive it responsibly/safely I can understand. That makes sense. Wanting to be able to switch maps because you're running a different/multiple fuel sources, I completely understand. If you have a 91 octane map and a 104 octane map, obviously the 104 octane map is going to likely be more aggressive, and will likely result in motor damage on 91 octane, it makes sense to have a separate map for fuel changes. Hell, it even makes sense if you're running meth injection in case you run out, or don't want to use it on the street but still want to drive WOT occasionally (maybe it's a PITA for you to come by, I don't know? lol).
However, wanting to drive around on a "detuned" map for "fuel economy" is retarded in my opinion. Want to know the secret of good fuel economy? Keep your car in CLOSED LOOP/partial throttle. Seriously, there it is folks. Don't know when your ECU is in closed loop? Buy a boost gauge and keep the needle below 0 haha. On top of that, buy a WBO2 gauge, and when it starts going richer than 14.7:1 (+/- 0.5 on average), there's your indicator, you're giving it too much throttle/introducing too much air into the motor, and your ECU is compensating by adding additional fuel/switching into Open Loop programming (read: much richer/more fuel used).
To anyone who is only planning to run 91 octane, and doesn't let anyone else drive their car, for the most part, the ability to change maps on the fly is pointless. Let me break this down:
-Car A is tuned for 10psi peak boost.
-Car B is tuned for 20psi peak boost.
^^^Both are identical in every way except the peak boost settings. Which one do you think gets better gas mileage under CLOSED LOOP driving (very light acceleration, cruising on the freeway, idling ect)? If you chose Car A, you're dead wrong, as they would both get identical fuel economy under closed loop as the ECU would simply try and target 14.7:1 AFR's. Although yes, under WOT/Open loop, Car A would be moving less air, and therefore require less fuel, giving it better fuel economy. As I said before though, the point is, if you want better gas mileage while driving around town, stop driving at WOT. Technically, you could also play with your OL/CL delays, to slow them down in order to try and make up for your lack of pedal control, but I wouldn't recommend that on a turbo car.... it's a recipe for detonation IMO. Want your car to last a long time? Don't beat the shit out of it. Seriously, it's that easy.
If you're at a light and you want to race Ricky Ricer in his Prelude (no comment lol), unless you're running a secondary fuel source (i.e. meth injection or have a fuel cell full of C16 ect) that you want to engage, there should be no reason to change maps on the fly. Like I mentioned above, fuel economy maps are pointless if you just learn to stay out of boost. If you're the type of person that "can't control yourself", and have to go WOT every chance you get regardless of the situation.... IMO, you don't need a secondary map, what you need is to learn a little bit of discipline and restraint. Don't blame the tool, blame the user.
Just my $.02
In other words, if you're worried about fuel economy, stop going WOT.
Mine: 2015 Subaru WRX
Hers: 2013 Subaru WRX
Eclipse
Postby Eclipse » Thu Dec 10, 2009 9:14
Youve always been known to explain things very well... or very indepth, whichever...
my whole point had absolutely nothing to do with fuel economy, but the secondary driver aspect. thanks for laying it out so EVERYBODY understands....(hopefully)
Powerstroke 6.0
roninsoldier83
OCD wrote:Youve always been known to explain things very well... or very indepth, whichever...
Yeah, I understood that your point had nothing to do with fuel economy, just wanted to clarify for anyone who didn't realize how a car's fuel system works.
I think what Chickenwafer was trying to say is that you don't need to adjust your entire "map" in order to lower the boost safely. If you tune for 18psi under WOT, then simply turn the boost down, your motor should be fine. If tuned correctly, there should be no need to touch timing or fuel tables when lowering boost, as they should compensate for the lower pressure if tuned correctly. Depending on how much you're turning the boost down, under WOT, it might run just a tad richer, which isn't going to hurt anything. Like I mentioned above, technically, with less pressure in the cylinders, you could likely adjust/add more timing or lean out the mixture a little more in order to make more power at a lower boost level... but if you're trying to detune the car in order to make it slower, it's kind of pointless isn't it? Haha.
Overall, what Chickenwafer was saying is that if he tuned his car with a flash or piggyback device of some sort, but let's say he was using a stupid simple MBC to control boost, he could tune for peak boost using his tuning device, and afterwards if he wanted, he could simply turn the boost down with his MBC, without touching any other setting, and the car would be just fine. I'm pretty sure that's what he was trying to say. You don't need to make a full map (to include tuning timing and fuel tables) in order to turn down the boost.
I'm pretty sure that's what he was trying to say :)
Eclipse
that makes complete sense... if the car is tuned proplerly for the max, it should be fine when the boost is turned down, or in my case, when the car is wife-proofed..
Again, for most people on this forum who use either the AP or the Standback, how many do you think ACTUALLY get the car tuned by somebody? Most all just run OTS maps, and raise the boost. FOR MOST PEOPLE ON HERE, the map switch on the Standback is more of a benefit than a gimmick... Like the norm, they will run an ots map, and raise boost on a map, with a stock or detuned map on another. An expensive boost controller, yes... but lets be real, the population of people with professional tunes on here is as close to as nill as you can get..
Powerstroke 6.0
roninsoldier83
OCD wrote:that makes complete sense... if the car is tuned proplerly for the max, it should be fine when the boost is turned down, or in my case, when the car is wife-proofed..
I'll agree with that :)
I do think it's a GREAT feature to be able to switch between multiple maps, however being able to do so on the fly is greatly overrated. Even for someone in your situation, being able to switch to a detuned boost setting for your wife to drive is not really something that needs to be done on the fly IMO. When I used to have an AP (switched over to Open Source/OpenECU quite a while back), I remember loading a RealTime map (vs a Base map) took under a minute, which I think is perfectly acceptable since you're just switching drivers. I'm not against switching maps, I just think the on-the-fly feature is overrated, as most people are set-it-and-forget-it type of people. Most people with an AP will load up their stage 1/2 base map ONCE, and just leave it there. They might talk about changing maps and whatnot, but in reality, they'll just keep the same map in there until they get parts that warrant a tune/switch of map.
You are definitely right about the lack of custom tuning here though... I know Nick tuned your MS6, Chickenwafer (Dave) custom tunes his own car, and I tuned my own MS6 when I had it (although I used MAC's dyno)... but really, that's just about it. Most people just play with the boost settings and don't do anything else.... and really, that's where most of the extra power comes from anyway, but many people don't realize the tuning is where you find increased reliability, consistency and a MUCH smoother powerband.
Me and Josh (SpeedRacer) have been in arguments about this in the past, as I never saw the point in spending all that money on a Standback to ONLY use it as a boost controller + MAP clamp. I always figured people should just save some cash in that case and simply buy a MBC + MAP clamp device (like the TXS FCD), as it's essentially doing the exact same thing. Actually, you'll never get the sort of boost response and consistency you can get from a MBC with any sort of electronic device/EBC, although some come close enough that you can't really tell the difference.
Mazda's have never really been "tuner" cars, which I always blamed on Mazda's insistence to make their ECU's extremely difficult to work with and very proprietary compared to many other vehicles. Although I must point out, that while the number of members over here that have had their car professionally/customer tuned is very small, over on AWDPirates or any other Subaru/EVO/DSM site, per capita you will find a TON of members that have custom tuned cars. It's pretty sad, as the 2.3 DISI has a TON of potential! With my old MS6, IIRC, I made around 285-ish-whp on MAC's dyno at only around 15psi on an uber antiquated TXS DTEC lol. For a 4-cylinder with a turbo the size of the puny K04's, that's amazing! For comparison, hit up the local VW guys, and see what their 4 cylinders (1.8T & 2.0T) make with the little K04 on them..... you'll be impressed with the 2.3 DISI motor hahaha!!
Thanks for the help bro!
I guess sometimes I just assume people know what I already know so I have a had time explaining things. I go from point A to point Z without filling in the gaps...
That was my whole point; closed loop and open loop. Airflow is airflow....you tune 300g/s OL in a certain load point and run XX timing and XX fuel. At 400g/s OL you run XX timing and XX fuel.
My map can run from idle (5 g/s) up to 500 g/s! That is an incredible range and a very wide range of boost pressures. But I have optimized timing and fueling for each load range. And then I cruise stoich in CL so my fuel economy doesn't change (at cruise) regardless of max boost pressure.
You don't switch drivers or fuel on-the-fly, and that is what I was trying to get at.
I don't really have anything else to say as you said all much better for me! Haha
Postby erod550 » Fri Dec 11, 2009 9:14
Heh, my wife is the same as roninsoldier's; she wants nothing to do with my car. "It's too loud" she always used to say about my SRT4. Don't have exhaust on the MS3 yet but will soon and she keeps trying to talk me out of it. Sorry babe, not going to happen. It's also funny watching her try to work the clutch in the MS3 because it is very touchy (I made her drive it just in case something happens that she has to drive it, it won't be the first time she's ever driven it). Even Nick at MAC was jerking a little trying to put it on the dyno. But yea even if she does drive it once in a while, she never goes WOT so changing the tune would have no effect since she'd never get into open loop.
As for professional tuning, I plan on having Nick tune my car once I get all the parts on it within the next month or two. These cars tend to have lean spots without tuning and I'd rather not blow my motor and I don't know enough about tuning to do it myself, so that will be $350 well-invested.
Postby chickenwafer » Fri Dec 11, 2009 9:14
Hell, my girlfriend is border line SCARED to just ride in my car. Forget about driving it! She hasn't driven the thing since I bought it with no parts on it. She teases about wanting to but she really doesn't want to.
Plus she can't handle the 400-lbs ACT Stage 4 clutch I have in that thing. Even if she could she would never go in boost! I scare her at 6psi, LOL.
But I get if you have a woman that want's to drive you car. If my girlfriend really wanted to drive my 8 and I assuming I would actually let her I would sure as hell turn my ebc off and let it run w/g spring.
Haha yea, even stock if I get on the gas she holds on for dear life like she's going to die. I can't wait to do a nice 3rd gear pull once I am modded. Might be the last time she rides in my car though lol.
roninsoldier83
Postby roninsoldier83 » Sat Dec 12, 2009 9:14
erod550 wrote:Haha yea, even stock if I get on the gas she holds on for dear life like she's going to die. I can't wait to do a nice 3rd gear pull once I am modded. Might be the last time she rides in my car though lol.
Nah, they get used to it :)
My STI on MAC's dyno is making 408wtq... at first the wife said it made her nautious whenever I did a pull, but she's ok with it now :D
