Threw a CEL at the track, last run.
- Rich
I'm still hitting fuel cut when the engine isn't quite warmed up. I don't really understand why, since my boost clip PSI is at 8 and I'm only running 16.7 lbs of boost. Usually happens at 70%+ throttle @ 3k rpm during first 5 mins of driving. And on acceleration I can hear my BOV fluttering if I'm not in WOT. I'm thinking it either needs adjustment or I just need to swap it for something else.
EvoXGuy
<div class='quotetop'>QUOTE (Rich @ Jun 15 2008, 01:09 PM) [url=index.php?act=findpost&pid=52182]<{POST_SNAPBACK}>[/url]</div>
What do you use to get your boost readings?
I'm still hitting fuel cut when the engine isn't quite warmed up. I don't really understand why, since my boost clip PSI is at 8 and I'm only running 16.7 lbs of boost. Usually happens at 70%+ throttle @ 3k rpm during first 5 mins of driving. And on acceleration I can hear my BOV fluttering if I'm not in WOT. I'm thinking it either needs adjustment or I just need to swap it for something else.[/b]
- Rich
<div class='quotetop'>QUOTE (EvoXGuy @ Jun 15 2008, 01:28 PM) [url=index.php?act=findpost&pid=52186]<{POST_SNAPBACK}>[/url]</div>
I'm only quoting the boost as I have it set for my primary map. I have a boost gauge, but I haven't installed yet as I'm still waiting on the custom pod for it.
What do you use to get your boost readings?[/b]
Users browsing this forum: No registered users and 115 guests
