Miata Engine Swap Help
Postby erod550 » Fri Mar 19, 2010 9:14
Yea I bought mine for a DD beater with no intent to mod, other than to fix it up a little. So far I've done the engine swap, new top, coilovers (just as the cheapest possible replacement for blown stock suspension), and a couple other little things like the headlights and horns. I'd love to get the katskin seats eventually but not anytime soon. For now it's just necessity stuff, but I've already put more than the cost of the car into it, heh. None of it was for performance increases though, just to get it into good running condition. It's pretty close right now. Just need to fix the windows. Passenger side rolls very hard and driver's side doesn't roll at all.
94mx5
Postby 94mx5 » Fri Mar 19, 2010 9:14
I ordered my headlights. They shipped out today. What do you think of yours? I am really looking forward to them!
They are definitely brighter than stock. I really need to reaim the passenger side light. It is way up and right and I'm sure I'm blinding everyone I pass. I light up all the signs on exit ramps, heh.
Postby erod550 » Tue Mar 30, 2010 9:14
More stuff done to the car this past weekend. Replaced the front left wheel hub/bearing assembly and both front rotors and pads. Almost 2k miles since the swap and still running strong. No leaks from the engine. My power steering rack has a slight leak and when I took it in for an alignment they told me it needed to be replaced. I'm putting that one off for a long time though because it's a very slow leak and I'll just keep putting fluid in it as needed.
RedRoadster
Postby RedRoadster » Tue Mar 30, 2010 9:14
I deleted the PS pump, drained the rack and pinched off the rack lines. I like the feel without the power, but Laura won't drive it now cause she can't turn the wheel while stopped.
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
I like my power steering. I want to keep it.
94mx5
Postby 94mx5 » Thu Apr 01, 2010 9:14
Can you rebuild it? I have rebuilt ps pumps before. Only cost $8 in a rebuild kit and less than an hour.
Postby erod550 » Thu Apr 01, 2010 9:14
Dunno, might have to look into that. I'm sure it's just a couple seals that need to be replaced. The rack works just fine, it just leaks a little.
Dange
Postby Dange » Fri Apr 02, 2010 9:14
hey i dunno if youve seen this link i did it with my old 1990 when i took the PS and AC out
according to flyin miata:
"If you want the fast ratio of a power steering rack with without the power assistance, you have several options. You can simply unhook the power steering belt but this leads to very heavy steering. The seals inside the rack are still trying to move fluid and the pump is in the way.
The next step would be to loop the lines around so that there's little resistance, but you're still pumping fluid.
The best way to do the job is to disassemble the rack and take the internal seals out. Here's how, starting with a rack that is already out of the car with the tie rods removed."
http://flyinmiata.com/tech/depower.php?x=1
04MSMGT
Postby erod550 » Fri Oct 29, 2010 9:14
Just went over 10,000 miles since the swap. Still running well.
Postby erod550 » Tue Jul 12, 2011 9:14
Now at 23k miles since the swap and no major problems. It's been a very reliable car so far.
94mx5
Postby 94mx5 » Tue Jul 12, 2011 9:14
Glad it still runs like a top for you! They are super reliable cars. Simple too. I am surprised that you only put 23k in 18 months. Figured it would have been more. Driving the Mustang more, huh? ;)
Postby erod550 » Wed Jul 13, 2011 9:14
Well, I put about 12k on my MS3 during the first year I had the Miata, and I've got 6500 on the Mustang so far. So I've still driven the Miata more than the other two combined. But I haven't been driving it full time, just splitting the miles up so I don't rack up so many on one car. I'm sure the Miata would take the miles just fine, but I get bored and miss my newer, nicer car so I have to take it to work at least once a week, heh.
94mx5
Postby 94mx5 » Fri Jul 15, 2011 9:14
Don't blame you. I have a DD as well, but it has been sitting more lately. Getting the other vehicles out some with the nicer weather. The little pos will see daily use again soon, and gets driven all winter.
Postby erod550 » Sat Jul 16, 2011 9:14
Pretty soon the Miata won't get driven much at all. Starting a new job on Wednesday working from home so no more commute to Denver. It will be my snow car though so it will get driven all winter on the studded snow tires. But I'll still take the Mustang out sometimes when it's not icy.
Users browsing this forum: Baidu [Spider] and 312 guests
