Turbosmart Dual BOV
METHLAB
Postby METHLAB » Wed Mar 26, 2008 9:14
So I'm running NO chance of damaging my turbo is what you're saying?
Postby SpeedRacer » Wed Mar 26, 2008 9:14
Yeah Shane your good man your closed loop :)
Firestone we have some hatahs up in here! lol It's cool tho we just haveta show'm the coolness we have.
RmSpeed6 I agree completely with what your saying because its all true ;) But who has truthfully tested running a hybrid and seeing how it effects things? Anyone? Anything but hearsay? Does anyone have proof of it hurting anything? What about an aftermarket BOV holding boost better than the stock what if all the pressure it builds actually hurts it? (talking outa my ass here now) Whose to say running 75% Recirc and 25% VTA is as bad as 100% recirc..
METHLAB
WAIT! I JUST FIGURED IT OUT!
Someone's is having their manhood threatened by the sheer awesomeness of my ms3...and want me to revert to stock setup to attain dominance. (like that shit, eh?)
HAHA!
METHLAB
<div class='quotetop'>QUOTE (SpeedRacer @ Mar 26 2008, 08:35 AM) [url=index.php?act=findpost&pid=35697]<{POST_SNAPBACK}>[/url]</div>
Yeah Shane your good man your closed loop :)[/b]
Meaning recirc, correct? Still learning the terminology.
Shane you teach me how to fly I'll teach you about your car ;) Yes Closed loop = Recirc your car is perfectly fine running what its running.
METHLAB
I'll take ya flying man. I think I mentioned it to someone. We could get a 4 seater and split the cost for an hour sometime. Just a thought.
I can has cheesburger.
Oooo How much does it cost?
S4poor
Postby S4poor » Wed Mar 26, 2008 9:14
<div class='quotetop'>QUOTE (METHLAB @ Mar 26 2008, 08:10 AM) [url=index.php?act=findpost&pid=35690]<{POST_SNAPBACK}>[/url]</div>
So then mine should be placed in the closed position? Stock BOV put back on maybe? It certainly isn't worth hurting my car for it.[/b]
I’m not trying to tell you what you should and shouldn’t do. I am just speaking from others (and my own) experiences. Your car, do what you want to with it. With that being said……
The MAF is used to determine how much Air is in the system from the time the air passes through the MAF, to the time it gets mixed with fuel. The MAF sends a voltage to the ECU, which adjusts the amount of Air to Fuel on a consistent basis. It even keeps track of this number between shifts. If the air is not recirculated, then the car will run rich. On cars with MAFs and BOVs, The MAF is usually repositioned somewhere after the BOV, not before.
Injected fuel can be determined by measuring the air-mass flow into the engine and divide it by the air/fuel stoichiometric ratio. The air-mass flow sensor may typically be located far from the cylinders, close to the air filter. Consequently there is a large volume consisting of hoses, intercooler, and intake manifold separating the air-mass flow sensor from the cylinders. Volumes introduce filling and emptying dynamics and a transient in the air- mass flow to the cylinders will therefore deviate from the measured air-mass.
Air flow to cylinders based on the Speed-density principle. The speed-density methods uses volumetric efficiency, engine speed, and intake manifold pressure and temperature to determine the air-mass flow to cylinder. A drawback of the speed-density methods is that the intake manifold pressure is subjected to noise. To reduce the intake manifold pressure noise, caused by engine pumping and standing waves, observed for mean intake manifold pressure have been proposed.
If we look at the motor more closely we will see that there are also a MAP and intake manifold temperature sensor present. The Mazda does not use the MAP to determine pressure, it is there just to "watch" that the highest pressure is not exceeded.
I believe Mazda also monitors the throttle plate angle (Still learning as much as possible on this) and of course the engine speed. It uses its air mass controller to boost to target air flow. For an example when the waste gate is opened the air mass flow decreases momentarily until the air-mass controller has opened the throttle more. This is done because the throttle controller tries to maintain a constant air mass flow.
Sooooo if we go and replace the BPV with a BOV the following will happen when gear is changed during WOT acceleration. When the throttle plate closes both a BPV and BOV will open. BOV tosses the air out and when the valve closes there will be an increased air flow through the MAF. I see that the error of measurement and mixture is caused by this rather than the all ready measured air being lost.
So not only will a surge hurt the snail overtime, the car will be running rich at certain moments. Rich is always better than lean, but neither will give optimal performance.
Again your ride, whatever makes you happy is also important ;-) Seeing yours also recic' air you should be good to go.
B-
Damnit we have ANOTHER smart person on the forum ugh... I gotta ban these smart people so I look smart... j/k lol Goodpost RMS6
S4poor
<div class='quotetop'>QUOTE (SpeedRacer @ Mar 26 2008, 09:09 AM) [url=index.php?act=findpost&pid=35716]<{POST_SNAPBACK}>[/url]</div>
Damnit we have ANOTHER smart person on the forum ugh... I gotta ban these smart people so I look smart... j/k lol Goodpost RMS6[/b]
If you're trying to look smart, start by utilizing proper spelling and punctuation instead of banning me. i.e. "Damnit & "Goodpost". Both are two separate words ;-)
Oh snap! No he didn't!
Totally kidding man, I try not to be technical with posts because I feel like a dork, but sometimes it's need to help others understand what I'm trying to say. Thanks for the Good post reply.
Now if only Methlab will teach me how to get my IFR ;-)
I know Good post is two words but i just woke up and i usually dont wake up till like noon since i work graveyard so i sleepy and im stickin to that excuse
Postby RX-7 Chris » Wed Mar 26, 2008 9:14
If you wanted to look smart by baning people. You would have to ban almost everyone one here. :6820a4ad:
I couldn't resist.
Lets just start with you...
S4poor
<div class='quotetop'>QUOTE (SpeedRacer @ Mar 26 2008, 09:24 AM) [url=index.php?act=findpost&pid=35724]<{POST_SNAPBACK}>[/url]</div>
I know Good post is two words but i just woke up and i usually dont wake up till like noon since i work graveyard so i sleepy and im stickin to that excuse[/b]
Like I said, just F'n with you ;-)
I know, you never explained running 75% recirc and 25% VTA and how that effects things
Users browsing this forum: No registered users and 85 guests
