My New Toy
Postby RX-7 Chris » Mon Jul 28, 2014 9:14
talked with the paint shop a bit ago. The car is painted. Once the paint has dried, car can be finished up. It will be ready Friday.
Postby RX-7 Chris » Thu Aug 28, 2014 9:14
I dropped the car off yesterday for it's final buffing, paint touch-up, and pin striping. I'm going to pick the car up tomorrow.
Postby Huzer » Thu Aug 28, 2014 9:14
Congrats on getting your car done (again)!
Postby RX-7 Chris » Tue Oct 14, 2014 9:14
I just ordered Caswell Epoxy Gas Tank Sealer Car Kit to take care of my tank rust problem. Once I get the tank taken car of, I'll send the fuel injectors out again for a cleaning. The sealer should be here some time next week. So I plan to do the work the weekend after.
This weekend, I'm going to install the new heater control valve. I'm not really excited about removing the entire dash. I'll be swapping out the carpet at the same time.
I'll get lots of pictures of this project.
Postby RX-7 Chris » Wed Oct 15, 2014 9:14
My new tires are ordered.
Falken ZE-512 ZIEX (HP) - 205/60R14
They should be in next week.
Postby RX-7 Chris » Fri Oct 17, 2014 9:14
I have the dash pulled.
It took me a total of 3 hours. I also cleaned my used replacement carpet.
I still need to pull a couple of pieces to replace the carpet (easy stuff). I also have to swap out the heater control valve, the heater box is already pulled.
Dwduc
Postby Dwduc » Fri Oct 17, 2014 9:14
WOW good work. Hope it goes back together easier, and you find as much money under your carpet as Huzer did!
Postby RX-7 Chris » Mon Oct 20, 2014 9:14
The car is back together and I have heat. Thanks to shadow for help putting everything back in.
Total time for the project was about 8 hours. It was way easier than I thought it would be. It could have been done in closer to 6 hours if it was just reinstalled instead of cleaned, etc. We cleaned all the parts before the install. I also put silver duct tape on all the heater pipes. The carpet was replaced finally as well.
I'll do a full how-to on this project.
Postby Shadowden » Mon Oct 20, 2014 9:14
I thought the new carpet really rejuvenated the car. Considering the cleanliness of the interior and the engine bay now, it's hard to imagine the car is as old as it is.
Postby RX-7 Chris » Mon Oct 27, 2014 9:14
I pulled the gas tank on Friday and sealed it. I went with Caswell Epoxy Gas Tank Sealer kit. http://www.caswellplating.com/restoration-aids/epoxy-gas-tank-sealer.html
It had really good reviews. What I liked about it is it's actually a 2 part epoxy. Other sealers are not. I used their 20 gallon kit. I have a 16 gallon tank but I do have baffles. The sealer is very thick which made it hard to work with. I do with I would have purchased 2 kits. I do think I got most of the tank sealed. The problem I had is there is no way to see how I did behind the baffles which cover any view of 2/3 of the inside of the tank. I do know I missed a few small spots in the area I can see.
I'll be re-installing the tank tonight. I was required to leave the tank in 70+deg for 24-36 hours. I had the tank in the garage with an electric heater blowing on it for the full day and a half. There is also a 3-4 day cure time before I can put gas back in it.
My fingers are crossed that this works.
Postby RX-7 Chris » Mon Nov 17, 2014 9:14
I ordered a new heater core for the car. The heater core was leaking as well as the heater control valve. I'll have to pull the dash back out. The core was supposed to arrive on the 11th through Rock Auto but it hasn't even left yet. I talked to them and It is ready to ship but the USPS isn't good at actually picking things up at that warehouse. This is the first time I've run into this.
I looked at getting a OEM heater core but it costs over $300 and the after market costs $85.
Postby Shadowden » Mon Nov 17, 2014 9:14
Need a nice warm day to pull the dash. Don't want cold/brittle tabs when it gets pulled.
Keep me posted!
true, and I really don't want to be working on it in the cold either, I also become brittle.
Postby RX-7 Chris » Fri Nov 21, 2014 9:14
The heater core is in. I plan to install it over thanksgiving weekend.
Postby erod550 » Fri Nov 21, 2014 9:14
RX-7 Chris wrote:My new tires are ordered.
I've had good experiences with that tire on my Miata. Handle pretty well in the summer and can even handle light snow.
Users browsing this forum: No registered users and 40 guests
