Another FD in the area
JTurton7
Postby JTurton7 » Tue Mar 06, 2012 9:14
ohhhh yeah
Postby speedjunkie » Tue Mar 06, 2012 9:14
Nice! At least your car's red, so you won't match John haha. Congrats!
Postby chickenwafer » Tue Mar 06, 2012 9:14
Nice man! Rota Grids? What sizes?
JTurton7
John's are 17s, I checked. These are 18x9.5 +38 getting a 20mm spacers for the rear. Still debating on what tire size to order. Yup rota grids.
Are you fenders rolled/pulled or modified at all? I would roll the fenders then you should be able to run a 255/40 no problem all around, or even 265/40 if you want more rubber, but it will be close in the rear with those spacers.
JTurton7
I need to get my fenders rolled. I was thinking just running a ricer riffic 235/40 all around. pretty much modeling my stance after this rx7
hes running 18x9.5 +38 front, 18x10in +15 on the rear with 225/35 F and 225/40 R
Postby chickenwafer » Wed Mar 07, 2012 9:14
Is that the Russian FD? I love that thing, those green wheels just set it off. 235's won't be that bad.
JTurton7
Postby JTurton7 » Wed Mar 07, 2012 9:14
hes from somewhere in Europe, i browse Driftworks which is a largely European forum.
BRC
Postby BRC » Wed Mar 07, 2012 9:14
hey i saw your car at the albertacos next to my work a week or so back! looks good too!
JTurton7
do you work at that tire place? if so got any tire deals? wink wink hahaha.
Car started smoking from the engine bay just now, spraying coolant from somewhere deep down by the turbos. Im assuming its that rubber hose N3A1-13-536 from the turbos to the engine.
Postby speedjunkie » Wed Mar 07, 2012 9:14
I blew one of those coolant hoses one time. It was the coolant feed hose to the turbos if I remember right. Can you see for sure where it's coming from?
JTurton7
the feed hose wasnt leaking. I can see coolant spray on the subframe so thats why im assuming/hoping its the return hose under the turbos. Ill get a closer look at it tomorrow before work.
Postby chickenwafer » Thu Mar 08, 2012 9:14
It's got to be either the turbo coolant return hose or even the heater hose. The turbo coolant hoses can be a bitch to get to.
JTurton7
Postby JTurton7 » Thu Mar 08, 2012 9:14
yeah looks like i have some fun work ahead. Cant locate the leak but can definitely see steam coming from the turbos somewhere deep down. Its a very small leak, no dripping just steam from the turbos.
Postby speedjunkie » Thu Mar 08, 2012 9:14
Have you been letting the car cool down and checking your coolant? Are you missing a lot or just a little?
