Car Electrical Issue...
I would look at the drain plug and the rear oil line.
- High Flying 8
- Member
It's hard to tell from the pics, but the oil is looking like it is coming from the front. If so, is it coming from behind the eccentric shaft pulley? That would be the main seal on the front cover that is bad-isn't too difficult to replace.
If the oil is coming from the top of the side or end plates and dripping down the side, it could be the internal o-rings on the dowels, which would mean a engine rebuild.
christi
I doubt it. This is a brand new motor and rebuilt. Atleast I hope not. I'll know more information tomorrow as I'll have jack stands and a jack to look at her. I'm thinking it may be the drain plug. I'll wipe off everything when I get home. And see if it's from there I guess. I'll check the oil filter too an see if anything is being dripped from there or of it's tight/loose.
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
This photo may not be of helpful. Maybe it will.
I still see a puddle of oil on this side of the car, it's on the body of the car... uhm, I can't think of the word right now.... sorry. Anyway, I felt underneath here where the light shines (see more from other photos), and oil is seeping through that. I haven't been able to check the drain plug, simply because I can't fit under neathe.... lol
Any ideas? Have Don look at the car next week? Take it .. say to Walmart to make sure the drain plug is tightly fit? Ideas? ... Mazda said they'd charge me 115$ to diagnose it... yah....
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
yeah you have to clean all the oil. I saw a good pound of oil under your subframe lol.
also if you want, you should take it to a local small shop and have them give you an estimate on the repair. Don't let them repair it but I'm sure you could get it diagnosed for free since most shops do free estimates.
I'll take a picture of the path of the oil cooler since I don't have p/s or a/c......
christi
subframe..that's the word. Yes, work has drained me with knowledge of it's own.
At any rate, any repair should be under warranty with Don... I shouldn't have to pay if it's leaking (assuming it's on the engine). ... picture would be great.
Tomorrow I'll have more leverage to do anything in the day time. Hoping I can borrow someone's jack and stands to get a feeler....
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi wrote:subframe..that's the word. Yes, work has drained me with knowledge of it's own.
At any rate, any repair should be under warranty with Don... I shouldn't have to pay if it's leaking. ... picture would be great.
first up is the front oil cooler line. (standing on driver side facing passenger side)
rear oil cooler line (its under the oil filter and under the oil pressure sender
oil pressure sender (the silver one with two yellow connecters, under the oil filter)
iani1.1 wrote:i hate you, i want your manual rack lol
haha, I actually mentioned that for you to read it
I still bet it's the oil cooler lines
christi
Okay.....I took it to Midas......
It's the oil pan that's leaking and the drain plug. Drain plug not so much....the oil pan very.#So....they're gonna fix it for me.
They can't find where the oil level sender plug should plug up to?
edit:
i apparently typed the last bit twice...
but anyway, the car should be done by 4p, and I get to walk another 5 miles to pick it up (and ... some how get my mazda 3 home). I hope this is all I have to do to this car.... Shes puttin' me in the hole, haha.
edit:
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
I'm now having a issue where the oil level buzzer is going off. It didn't before. There is oil in the car. Any ideas....
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
It's because the oil level sensor isn't hooked up.
christi
oil level sensor is the wire hanging down? but what would explain.. that it NEVER came before I got the oil pan changed. Now it's on.
The wire has no where to plug up to.... I think it was cut during the process of removing the emissions....
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
- SecondGenPAt
christi wrote:The wire has no where to plug up to.... I think it was cut during the process of removing the emissions....
The only wires that were cut were for the 5 solenoids that use to reside behind the p/s pump.
I am fairly certain that there is just 1, 1 wire connector that the oil level sender plugs into. (grounds through block)
I am just going to stop there since Midas was mentioned... (you get what you pay for at those places)
