Miata Engine Swap Help
Slowly coming together, heh. Now just have to fix the suspension and the rear window and the steering boots and and and...
Old cars, fun to work on but it's a never ending process, heh.
Surprisingly for me, there is generally an end. I usually put the laundry list together of what I want it to look like when I am done, and slowly knock things off the list. Of course hiccups happen along the way as minor things are found wrong, but generally there is an actual "end" point. Then it is time to find another project.
94mx5 wrote:Surprisingly for me, there is generally an end. I usually put the laundry list together of what I want it to look like when I am done, and slowly knock things off the list. Of course hiccups happen along the way as minor things are found wrong, but generally there is an actual "end" point. Then it is time to find another project.
There are times when I wouldn't believe you, like now. LOL
Just wanted to give an update. 1,000+ miles since the swap and she's still running strong. Still more work to do on other stuff but the engine and transmission are doing great.
Lol. I am tapped out money-wise so no turbo kit any time soon. Plus I'm pretty sure this clutch would disintegrate nearly instantly. As it is it slips a lot if I take it up to 6k.
Tried to glue in a new piece of vinyl for the rear window and it looked like it was going to hold after sitting overnight. Then I tried to zip up the curtain and it all came loose. The glue just wasn't strong enough to handle the tension. Yes I unlatched the top before zipping it up to take the tension off the zipper area. But when I latched the top one whole side came off. Turned out it wasn't lined up the best but it's hard to line it up perfect with the curtain folded down and that's the only way you can put pressure on the glue to hold is if it's laying flat. But I was able to peel away some more of the glue so I don't think the glue was strong enough to hold it long term anyway.
So for now I have just duct taped the whole thing in the areas where the glue came apart and just won't put the top down for a while. I think I'm just going to bite the bullet and order a new top. Then I won't have to worry about the window or the top for many years to come.
Decided to order a Robbins factory style vinyl top with zippered non-defroster glass window. This car is a money pit lol. But this top should last me a very long time and with the glass window I won't have to worry about going through what I just went through with trying to replace a clouded/torn plastic window.
You won't be disappointed with the top. $ says that you will find it was the best investment. We had a Robbin's no-zip glass top on our first Miata. It was FABULOUS. Figure about a 6-10 year life even if it sees a fair amount of sun. Keep it garaged or covered, it could last the life of the car. Will make the drive SO much nicer too! No faded or cracked windows.
Yea. I wanted to keep the option to drive around with the window unzipped without putting the top down if I wanted to. So that's why I didn't go with zipperless. And I wanted to just spend the extra money and get a good quality top rather than an eBay top that may only last a year or two, if I could even get it to fit right in the first place.
Hopefully it will come in this week and I'll do it next weekend. I think the duct tape will hold for a week, or two if it doesn't come in this week (I hope).
- Dange
miatas are money pit, but the benifit, parts are pretty cheap they are damn near bulletproof besides the shortnose you took care of and the tiny diff that the pre 93 cars came with
if you ever need any help lemme know ive had one 90 na and the msm in the last 4 years,
na had a full restoration, 1.8l exedy stage1 and fidanza 8lb flywheel, full intake, header back exhaust, coilovers, chassis braces, rb front rear sways, 1.8 brake conversion, 15x8 wheels, falken azenis, new top, new dash, new katskin seats, and had just gotten a hdhcdd roll bar for it before the incident...
and i bought it for a dd beater with no intent to really mod.
04MSMGT
Users browsing this forum: Baidu [Spider] and 312 guests
