Calling MS3 owners, whats your PSI?
bobopud wrote:These graphs alone should be enough to convince someone to get an AP or standback. Without the AP I was in the same boat, peak at 14 PSI and taper off to 9 PSI by redline. With the AP I now peak at 18-19PSI and hold 16 PSI to redline.
Granted this turbo is not efficient past 15PSI at this altitude, but it still makes for a lot more power available in the upper rpm range.
mOOsE wrote:no kidding, I am jones'n for the AP. If anything to restore the missing PSI. Going to sealevel will quickly reveal the 3rd gear difference in power...big time
So, if engine mngmt. will allow you to hold boost and get more available power, how much of an effect will this have on longevity/reliability? Are we just making up for the high altitude, or are we negatively messing with the power output that Mazda intended...only to have an immediate power gain, but a boom-boom down the road:huh:?
kingtut wrote:So, if engine mngmt. will allow you to hold boost and get more available power, how much of an effect will this have on longevity/reliability? Are we just making up for the high altitude, or are we negatively messing with the power output that Mazda intended...only to have an immediate power gain, but a boom-boom down the road:huh:?
There is always that chance, but at this altitude, we can definitely crank up the boost for what we have lost. That's one of those questions that nobody can give a def answer on unfortunately.
mOOsE wrote:Quick educational update for those interested. I recently visited near-sea level with my MS3. Did a couple logs for kicks and voila...perfect Boost...or near. I even hit 17psi in 4th which quickly tapered down and held at 15psi. 1+2 gear were hitting 13-14psi as well. Looks like I will be investing in an AP before a BOV as mine is clearly working fine. For reference, my highest PSI in Colorado was 13psi, generally tapering down to 11-12.So I am losing 3-4 psi from elevation
Makes me a sad panda, but hey, its not leaking
Now that I have a functioning gauge... I seem to be hitting 13psi max (generally using third to test). During WOT, I'm anywhere from 11-13psi on average.
Users browsing this forum: No registered users and 138 guests
