Miata Engine Swap Help
S'ok. Should only be a couple bucks from the dealer. And then I'll change it myself next time with the oil/filter I already bought.
Some pics from the ordeal.
Old engine completely out
New engine ready to go in
Didn't take any pics as we were putting the new one in because for one, we were frustrated getting the motor mounts lined up, and for two, it looks the same, just backwards, heh.
No pics of the new engine?
Look at the last line of the above post, hehe. I'll get a pic sometime soon of the new one, but it looks just like the old one.
lol, I didn't see that
you need to get that engine bay decreased. I bet it would clean up real good.
Yea, it's pretty dirty under there.
I'm still having trouble with the accelerator cable. I've adjusted it as far as it will go but it's at the end of the threads. I'm starting to wonder if maybe it got pinched when we were putting the new engine in and is getting stuck or something. Is there anything I can adjust on the throttle body to turn that wheel a bit so the cable doesn't have to reach as far?
BTW got the sway bar back on. Was easier than I thought. It actually is possible to weave it through everything without taking anything apart. Just have to have the car up real high so you can get the right angles. Also replaced the radiator fan switch so the fan isn't running all the time. And got that coolant reservoir replaced.
I'm wondering if it has something to do with what the person in this thread is talking about.
http://forum.miata.net/vb/showthread.php?t=364305&highlight=throttle+cable
Are there other things that may need to be adjusted that could be keeping the idle high? I'm pretty sure it's just the throttle cable since I can lift up on the pedal and get it to drop to about 1000rpms, but it never drops to 800.
I would try pulling the cable off the throttle body and out of the way and then reinstalling it. If you want, I might be able to look at it this weekend.
Yea I have done that and the revs do drop. So yea I'm thinking maybe I should swap to the old throttle body. Should I swap the entire intake plenum or can I just swap the throttle body?
The entire intake isn't a big deal. That would be 1 hour or less. The biggest PITA is getting to the few bolts on the underside. Other than that, it is straight forward. I wasn't aware of a different length on the intakes, but I could be wrong. First I might measure the side/side and see if you can find a slight difference.
