2nd Gear Shifting Issues
ZoomPrincess
Postby ZoomPrincess » Thu Jan 31, 2008 9:14
Oh I know exactly the problem you are having with the shifting. I had the same problem in Josh's RX, he never believed me, said it was my driving until one day it happened to him.
Postby GR-8 » Thu Jan 31, 2008 9:14
When you go up there ask Ed to go along for a short drive. Maybe see if he can get you into a new 8 and have him feel the difference in shifting. I remember the 8 used to be silky smooth when shifting. Especially at high rpm's. Now there's like a pushback or something... I can't describe it right...There's jsut something holding it back.
Buffalo
Postby Buffalo » Thu Jan 31, 2008 9:14
That is because i feel strongly about only taking my car to Burt and about Mazda as a company. It seems to me they take care of their own.
<div class='quotetop'>QUOTE (6i_guy @ Jan 18 2008, 10:18 PM) [url=index.php?act=findpost&pid=19321]<{POST_SNAPBACK}>[/url]</div>
you sound like commercial dude. -_-[/b]
Up Next: Project RX-8!
Postby Huzer21 » Thu Jan 31, 2008 9:14
<div class='quotetop'>QUOTE (Greek8 @ Jan 31 2008, 03:42 PM) [url=index.php?act=findpost&pid=21928]<{POST_SNAPBACK}>[/url]</div>
When you go up there ask Ed to go along for a short drive. Maybe see if he can get you into a new 8 and have him feel the difference in shifting. I remember the 8 used to be silky smooth when shifting. Especially at high rpm's. Now there's like a pushback or something... I can't describe it right...There's jsut something holding it back.[/b]
I might. The related issues I've found on RX8club tend to mention it being clutch related. (And the clutch itself was replaced under warranty in 11/06) Even Ed mentioned a clutch issue. Clutch, transmission, I don't care what is the source of the problem, I just want it fixed.
The 3 main issues I've heard of are:
1. Manual Transmission - Clutch Hard to Disengage. http://www.finishlineperformance.com/pdf/r...04-06-1641a.pdf
2. A broken clutch pedal bracket assembly.
3. Loose pressure plate bolts.
<div class='quotetop'>QUOTE (Huzer21 @ Jan 31 2008, 03:53 PM) [url=index.php?act=findpost&pid=21931]<{POST_SNAPBACK}>[/url]</div>
3. Loose pressure plate bolts.[/b]
Is it hard to change from 1st to 2nd while at a dead stop. I feel that pushback or hardness to shift when at a dead stop.
Just read the bulliten. That seems like it's it. Shouldn't this be considered a recall. Nice find. There is a massive amount of free play in the cluthch which would probably lead it to not fully disengaging.
Talked to Ed again, apparently they drove it around in the parking lot. They don't think it's any of the above and that there are no problems.
Postby SpeedRacer » Thu Jan 31, 2008 9:14
ugh fuck dude that sucks
Do we need to bring CMZC down upon their ass?
Oh well. For now, I'll put in some Redline, put on the stainless clutch line, and check a couple of things I've read about. For now, I'll let it go. I'm under warranty another year and a half so it's no biggie.
NICE
Postby Huzer21 » Fri Feb 01, 2008 9:14
Well, I tried to be open minded today driving. I did tell the folks at Burt that the issues started at around 5k, and to be honest, I didn't feel anything other than a touch of stiffness. It's really when you get more toward the 8k mark that it's noticeable. As I said, I'll check a few things myself before I talk to anyone about it again.
Quick Edit: Funny thing, when I called Ed yesterday to check the status on the car, the first thing he said was "Yeah...the one with the short shifter!" Haha.
LM
Postby LM » Fri Feb 01, 2008 9:14
I was wondering...does anyone know if the gearbox from the RX-8 is the same as the one in the Speed6's??? I only ask as I also have an issue with changing from 1st-2nd gear...the other gears are real smooth....it's just going into 2nd.
That, I'm not sure of.
Buffalo
Postby Buffalo » Fri Feb 01, 2008 9:14
I think that the new 09 will have the same gears as the speed 6. But as for now i think that they are different.
