I looked at this place back when i was thinking of doing it:
http://www.eastbaycomposites.com/
Shadowden's Mazda3 Build thread
- AuroraAxela
Wonder if I can make body panels with kits like that.... hmmm:723b3bdf:
RX-7 Chris wrote:I looked at this place back when i was thinking of doing it:
Thanks Chris. What I have planned is pretty big and will require the ability to carry some load. I was planning to cover the custom box/hatch cover I build with the cloth, and also make a solid floor for the hatch area and cover it in the cloth. I am also considering doing the side panels in the hatch. That is a ton of Carbon Fiber though. The hatch floor will be covered with a rubber mat 99% of the time. That would only come out for shows. So in short, I wouldn't really be making CF parts, just covering some parts with carbon fiber. I like the CF switch covers though, and it seems like I am going to have to do a wet build up similar to how those switch covers were done.
My plan was to build the box and floor, then cover them both in a layer of fiberglass or two, then sand smooth, cover in bondo, sand smooth, then lay up a layer of carbon fiber. The problem I see here is that my final step is brushing on the epoxy from the top and getting a nice even and smooth finish. It will probably take a couple of coats of the epoxy on top and then, I figured I would need to use a polishing compund and finish with several coats of clear coat.
Any weaknesses in my thought process?
Right now I am committed to buy some sway bars from another member at the end of the month. Don't have a lot of modding cash at the moment, but yes I am interested as long as the system is intact and rust free.
Sway bar information for future reference
http://www.mazda3forums.com/index.php?topic=156031.0
You would probably want to blow out some of the carbon, and you will have to put a v-clamp on it because I'm going to have to cut it in the middle to get it out. As for rust, shouldn't really have much at all, it's only got 33k on it, and I washed it religiously. I'll let you know once I get under it again.
- AuroraAxela
V-clamp hell. Carbon, my ###. Please see my thread.
- AuroraAxela
By the way, you still thinking about getting rid of your Simota?
- AuroraAxela
No, exhaust pros did the whole thing for around 225 if I recall correctly. Can't weld it first because you would have to pull the rear cross member out to install the complete unit, which would mess up the alignment (bad design).
Plus there's some custom fabrication to be done. See my thread, and I can tell you more at the meet
AuroraAxela wrote:No, exhaust pros did the whole thing for around 225 if I recall correctly. Can't weld it first because you would have to pull the rear cross member out to install the complete unit, which would mess up the alignment (bad design).
hmmm....having the exhaust in hand with no install money would be no bueno. That is a fair chunk. I'll have to look into it more.
225 for your exhaust? that include buying it? i got mine installed for 70 and the exhaust was 80. They welded it and put it on, nothing special needed besides extending the tip cuz i have a sedan
And shadowden if you can find the exhaust now id say get it now until you can install it. i had mine sitting in my backyard for 6 months till i decided to get it done
- AuroraAxela
I'm not sure how much it was, that was like 2 months ago.
I'll call him soon and find out. I did get a custom tip, I know that was part of the price...
- SecondGenPAt
Shadowden wrote:Sway bar information for future reference
oh my goodness that was a funny read. Granted I couldn't read more than the first page due to sheer disbelief in those FFF's. I like how they kept using "snap oversteer" to describe FWD's, that was hilarious. I did not see one person say anything about altering spring rates or damper settings to balance the thicker bars to counter over vs. understeer characteristics Oh well, need my entertainment from somewhere.
Hakuna Matata
I'm betting that most of them were on stock springs, or stock dampers at a minimum. I'm on eibach pro kits, and Koni yellows in the rear...still stock struts at the moment as they are riding well. NOt many folks on performance coil overs in these cars except to "stance", even then, I think most are on "cheap" coilovers just to slam them down.
Users browsing this forum: Baidu [Spider] and 64 guests
