Well, finally I have the eyelids sprayed. Now all i have to do is wait for them to cure so i can get them clear bra/coated...
So here is what I did:
Got everything together that I needed...
Next was to get some primer going. Two thin coats with a final slightly heavier coat. Then a gentle going over with some wet 1000 grade paper.
Next was the base coat. Again, two thin coats with a final heavier coat...getting the 1000 grade paper out when needed to keep things smooth.
Next was the mid coat...three helpings there. Then one thin lashing of clear coat followed two heavier coats to finish it off.
Here is one laid in played, but not yet attached.
I'll post some more pics once it's clear bra/coat is on and they are attached...
