First Gen RX-7 Part Out
Postby RX-7 Chris » Wed May 11, 2011 9:14
I actually sold the rear hatch switch and button over the weekend.
Updated List:
I've removed some parts that are gone, added others, and clarified some.
All prices do not include shipping and are negotiable. I can post more details and pictures if requested.
-+ wheels with almost new Sumitomo HTR 200 (5k on them) - $230 (4)
-Storage bin lids 84-85 grey - $10 (2)
-Hood - $20 pickup only
-Cowl cover 84-85 - $15
-Door glass - $50 pr (have a few sets)
-air filter assembly (holes plugged with silicone but I can remove it someone wants) - $20
-new shutter valve still in box from Mazdatrix - $50
-partial wiring harness for '83 (was cut at firewall so everything from firewall back) - $30
-79-83 grey dash cover - $10
-81-83 pocket under radio - $5
-81-83 column cover set - $20 (2 sets)
-81-83 GSL emblems – 15 pr (2 pr)
-maroon sun visors missing mounting tabs - $10 (2)
-81-83 LCD clock working - $20
-84-85 12A computer - $30
-81-85 12A choke with slightly frayed cable and good knob - $40
-81-85 amber side marker set - $20
-83 air control valve - $40
-black door sills pr - $30
-84-85 ash tray (just removable tray) - $5
-84-85 grey shift boot great condition - $15
-81-83 dash light brightness switch - $15
-81-83 heater control unit with knobs and faceplate - $25
-trim over door black - $10 each
-Door windlace black - $10 each
-81-83 dash bolt cover (1 maroon, 2 black) - $2 each
-81-83 glove box light switch- $3
-81-83 Headlight switch w/o cruise control includes turn signal automatic canceling cam - $50
-Horns pair - $15
-81-85 overflow tank 12a w/ mount - $20
-79-83 washer tank w/ mount and pump - $30
-79-83 Gas Pedal Pad New - $7
-79-83 Brake or Clutch pad (used 2 years, great shape) - $3
-81-85 Dead Pedal assembly - $10
-Rear window interior trim passenger side with wiring black - $15
-Rear window interior trim driver's side dyed black - $10
-Gas tank filler assembly - $20
-81-83 ash tray assembly - $10
-81-83 equalizer (not tested) - $10
I added a few things to the end of the list and I have more parts to come soon.
Postby RX-7 Chris » Tue May 17, 2011 9:14
Wheels and tires SOLD
Postby RX-7 Chris » Mon May 23, 2011 9:14
The car is almost completely pulled apart. I have to still pull the motor and parts out of the doors. If there is any odball parts that someone might want let me know this week because I plan to have the car gone next week.
I will be posting the rest of the parts in the next few days.
G-Man
Postby G-Man » Mon May 23, 2011 9:14
Hi Chris,
Please check your PMs. Thanks, G-Man
Postby RX-7 Chris » Wed Jun 01, 2011 9:14
Headlight assembly (no motors) a bit rough but good bulbs - $10 each
parking brake handle - $10
81-83 brake/clutch assembly (includes switches for brake light and CC) - $40
81-83 (79-80?) gas peddle assembly - $15
charcol canister with bracket - $10
radiator supports - $20 pr
gas tank shield - $5
radiator upper front cover - $10
antenna wire - $5
hood latch - $5
84-85 shifter (boot is shot) - $5
coil bracket - $10
fuse block cover - $5
79-83 vent great shape - $10 each
brake master vacuum tube - $5
coolant tube - $5
81-83 GSL (for rear disk car) brake master with proportioning valve (master is a remanufactured unit and about a year old) - $50
81-83 clutch master (remanufactured unit and about a year old) - $15
83 heater fan with box - $30
A/C box with good evaporator - $30
heater box with good heater core - $40
81-83 heater vent tubes - $10 all
computers - $50 all
rear driver's caliper with bracket not tested - $10
water pump - $10
Pulleys - $5 each
alternator bracket - $5
rear trim piece painted - $5
door locks, black - $5 pr
steering column bracket - $5
The final parts list
Postby RX-7 Chris » Tue Dec 20, 2011 9:14
I'm cleaning out all the parts I have left from my old car in the garage and I number of other parts I don't need anymore. I listed everything I have.
All prices are negotiable. I can post more details and pictures if requested. I want this stuff gone so make some offers.
-81-83 dash bolt cover (1 maroon, 2 black) - $1 each
-Horns pair - $15
-Headlight assembly (no motors) a bit rough but good bulbs - $10 each
-parking brake handle - $10
-81-83 brake/clutch assembly (includes switches for brake light and CC) - $40
-81-83 (79-80?) gas pedal assembly - $15
-charcoal canister with bracket - $10
-gas tank shield - $5
-radiator upper front cover - $10
-antenna wire - $5
-hood latch - $5
-84-85 shifter (boot is shot) - $5
-coil bracket - $10
-fuse block cover - $5
-79-83 vent great shape - $10 each
-brake master vacuum tube - $5
-coolant tube - $5
-81-83 GSL (for rear disk car) brake master with proportioning valve (master is a remanufactured unit and about a year old) - $50
-81-83 clutch master (remanufactured unit and about a year old) - $15
-83 heater fan with box - $30
-A/C box with good evaporator - $30
-heater box with good heater core - $40
-81-83 heater vent tubes - $10 all
-83 computers - $50 all
-water pump - $10
-Pulleys - $5 each
-alternator bracket - $5
-door locks, black - $5 pr
-steering column bracket - $5
-12A motor parts (let me know what you may want and I will get pics and price)
G-Man
Postby G-Man » Tue Dec 20, 2011 9:14
Hi Chris - Sent you a PM on a couple of things. Thanks!
Postby RX-7 Chris » Wed Dec 21, 2011 9:14
G-Man wrote:Hi Chris - Sent you a PM on a couple of things. Thanks!
I sent you an email
alex_n/a
Postby alex_n/a » Wed Dec 21, 2011 9:14
how much for a rotor or two?
I want a rotor for decorative reasons so if you happen to have a junk rotor laying around somewhere let me know.
thanks.
83Limited
Junior Member
Postby 83Limited » Thu Jan 12, 2012 9:14
RX-7 Chris wrote:I'm cleaning out all the parts I have left from my old car in the garage and I number of other parts I don't need anymore. I listed everything I have.
-Horns pair - $15
-antenna wire - $5
-hood latch - $5
-coil bracket - $10
-coolant tube - $5
-water pump - $10
-Pulleys - $5 each
Pm sent on a few of the 83 parts. Thanks.
Barron
Griffin, GA
83 Limited Edition
