Miata Engine Swap Help
I can probably fit another couple small jackstands in the Miata if you still will need them. It's about packed right now with fluid containers and seals and a radiator. I'm not sure if I'll actually need to replace the radiator as I originally thought it was leaking but the last couple days I checked it has still been full. But I'm bringing it just in case.
I will be there around 1:30 and have to leave around 4:30.
Engine swap is well under way!
When I left at 11:30 the following was done:
Hood off
PS pump off
AC compressor off
Most of engine wiring undone
Radiator removed
NEW radiator prepped for re-install
Driveshaft removed
Trans drained
Engine mounts unbolted
Exhaust split before cat
Ex manifold being unbolted
I suspect the engine/trans are out by now!
Hood off
PS pump off
AC compressor off
Radiator removed
Driveshaft removed
Trans drained
So did it get finished?
When I left the motor was almost to the point where it could be bolted in, just needed to be lowered another 6" or so.
Unsure if it got finished. They called last night around 7:30 indicating they couldn't get the mounts lined up with the K-frame. Said that had been at it for nearly 4 hours just trying to get the mounts to line up. I was taking care of some work last night and had to get up early this morning for work. Unsure what the end result was.
Well it's done and I'm home. New engine is running fine, I just think I have a coolant leak somewhere as it went through the amount in the overflow reservoir and I can smell burnt coolant after driving it for a while. So I need to find out where that's coming from. Also, the throttle body on the new motor seems to be in a little different position from the old one because my accelerator cable is a little too short so it doesn't want to idle down, wants to stay around 1500-2000rpms unless I put my foot under the gas pedal and lift up on it. So I need to do some adjusting there.
Oh, and as I was buttoning everything back up, bumper back on, ready to clean up and go home, I realized I never put the sway bar back on. So it's in the trunk right now. Still drives ok, just is a little skittish over big bumps. I'll get it back on probably next weekend, but there was no way I was going to take more stuff apart to get it back on there today. Had already spent about 13 hours on it yesterday and another 8 today so I was pretty tired of working on it by that point, heh.
Many thanks to those that helped though, especially Ron for letting me use his tools and garage and letting me crash there overnight when we didn't get it done in time.
Glad to hear that you got it done. I was worried for a little bit. It sound like the throttle linkage just need to be adjusted and you should be fine. How does the new motor run compared to the old? Is there a difference? Did it fire right up or did you have to mess with it a little?
Those motor mounts were a pane. 4 hours trying to get it in.
That sucks about the motor mounts. When I left, I thought they would just go right in, lol. Glad you got it going again.
Yep, started up first try. It was running very rough and I gave it a little gas and it almost stalled. Check engine light was on also. Then I realized I hadn't plugged in the MAF. Shut off the car, plugged it in, and it ran fine, though did smoke a bit, but I'm guessing that was just spilled fluids burning off. I got transmission fluid on quite a few things while trying to fill it back up. Seems to run at least as good as the old one. The concern with the old one wasn't so much how it was running now, it was how much longer the crank would last in it because of the issues the '90s-early '91s had. The new motor sounds like there is some valve ticking going on but from what I've been reading that is very common on Miata engines and a good oil clears that up. I couldn't get the drain plug off as it was already partially rounded and I rounded it the rest of the way so I'm going to have to take it somewhere and get the oil and filter changed soon. Probably take it to the dealer as they will have a factory drain plug to replace it with.
The new transmission makes a lot less noise than the old one, though it's a little rough shifting into and out of reverse, but it has loosened up some. And my reverse lights aren't working and neither is the parking brake dash light, so I think I may have plugged those in backwards or something. Both had two identical plugs and I didn't know which was which so I just plugged them in. I'll do a little research on that and maybe fix them next weekend. I'm so sore right now I'm not even trying to work on anything else today.
As for it taking 4 hours to line up the motor mounts, we started with the bumper on and realized that wasn't going to work because the hoist couldn't get in far enough, so we had to back out and take it off, then we ended up having to back out and take off the Cam Angle Sensor because it was hitting the firewall and that gave us another 2-3 inches. Plus we eventually jacked up the transmission from below to level everything out while we were trying to wiggle it in there, so I bet if we were to do it again we could get it in in less than an hour. I hope I never have to do it again though. :P
I'm really glad you had the Haynes manual, Ron. Without it I never would have been able to get all that stuff back together by myself. I didn't know how the tensioner worked exactly on the power steering pump and also wasn't sure where the transmission fill plug was and found both of those in the Haynes manual. So between that and a few searches on Miata.net I got it done somehow. I was seriously thinking there's no way it's going to fire right up but it did. And ran great coming home except for the burning coolant smell when stopped. I think that might have something to do with the old reservoir being cracked on top and it might be boiling out of there and getting on stuff. I think I will throw some duct tape over the cracks until I can get the replacement in there. I'll have to undo some other things to get it out so I don't feel like doing that today.
Good news, just went out and checked under the car, no leaks. So that cracked overflow tank has to be the culprit. I've duct taped the crack for now. We'll see if that helps. Still need to adjust the throttle cable.
- RedRoadster
1) ticking: look up the 2twisty flush and/or seafoam on m.net
2) drain plug: I might have an extra one in the garage. I'll follow up when i get home.
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
Flyin' Miata stuff:
Sounds like all the current issues are expected with a swap. I typically get a bit of smoke due to spilled fluids. The coolant issue sounds like it wasn't a big deal as it seemed to be doing it before. I had only put that overflow hose on a day before you picked up the car. It was previously missing. Now we know why maybe. The valve tick can be the lifters. They can change over time a bit and with an oil change. If needed, the valve lifters can be swapped. Not a huge deal. Takes a few hours even if you don't know what you are doing. The hardest part is getting the t-belt lined up again if you have never done a t-belt before.
- RedRoadster
No drain plug off my old engine.. sorry.
Flyin' Miata stuff:
Flyin' Miata stuff:
Users browsing this forum: Baidu [Spider] and 312 guests
