The S2000
Postby Shadowden » Mon Dec 10, 2012 9:14
tsx_guy wrote:looks great in the pics...
I tihnk it will be fine on...but I seek perfection...
Postby Shadowden » Fri Dec 14, 2012 9:14
I started sanding down my extra bumper last night. Found a few more marks than I realized, but it should clean up very nice and will provide me the opportunity to work on learning some simple autobody basics. I plan on taking this bumper to the point of wetsanding the primer, then it will go to the autobody shop for laying the metallic paint and clear coat.
Does anyone happen to know the name of the auto body supply store in Littleton? I bought some thin painters tape from them in the past, but can't recall the shop name, or where it was. I know Allen Paint is on Broadway in Englewood/Denver.
ecam for the win
[ame="http://www.youtube.com/watch?v=evwQrchjQbM"]TX2K12 - 8 Second 2JZ S2000 Giant Wheelie! - YouTube[/ame]
SecondGenPAt
Postby SecondGenPAt » Sat Dec 15, 2012 9:14
If you didn't have enough to read for school...
http://www.motoiq.com/projects/honda/project_honda_s2000.aspx
Hakuna Matata
Postby Shadowden » Mon Dec 17, 2012 9:14
Yeah, I am contemplating an AP2 tranny and replacing the clutch at the same time. I was thinking of a stage 2 competitin Clutch. Lots of good reading. I read up on swapping the tranny, and it isn't terribly difficult, but it isn't exactly easy either. Will have to get ecam involved for sure.
Shadowden wrote:Yeah, I am contemplating an AP2 tranny and replacing the clutch at the same time. I was thinking of a stage 2 competitin Clutch. Lots of good reading. I read up on swapping the tranny, and it isn't terribly difficult, but it isn't exactly easy either. Will have to get ecam involved for sure.
Clutch change/tranny swap info
http://www.s2ki.com/s2000/topic/83548-clutch-replacement-diy-aftermarket-winners/
http://www.competitionclutch.com/products/s2000/
http://www.scienceofspeed.com/discontinued_products/Competition_Clutch/clutch_kit/
http://www.andysautosport.com/honda/2000_9999_s2000/transmission/clutch_kits/competition_clutch/
Some have recommended the Exedy clutch
http://www.allreplacement.com/product/3399
IPW $405.21 (local)
Postby Shadowden » Fri Dec 21, 2012 9:14
Was told oil temp is something i should monitor for the track and my car is lacking a clock, so going to do these after Christmas:
Pillar pod
http://www.speedhut.com/ecommerce/product/766/S2000-2000+--Dual-Gauge-Full-Pillar-Pod
customizable analog clock
http://www.speedhut.com/gauges/Clocks/1:16
Prosport gauges
http://prosportgauges.com/Blue-white-premium-oil-temperature-gauge-.aspx
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
Postby Shadowden » Sun Dec 23, 2012 9:14
Swapped out my valve cover today. Went pretty well. The torque specs for the bolts is lower than my torque wrench measures accurately (8.7 ft/lbs), so I dialed it to about that setting and snugged them up after tightening them up in the appropriate pattern in 2 passes. Hopefully it is good, I'll find out soon.
Before:
After:
Postby geo2maz » Sun Dec 23, 2012 9:14
looks great!
_AlexTM
Postby _AlexTM » Mon Dec 24, 2012 9:14
I like it
SOLD 2004 Mazda3 hatch
Postby RX-7 Chris » Wed Dec 26, 2012 9:14
+1 ^^
Postby Huzer » Wed Dec 26, 2012 9:14
King Ricer, I approve. I like it.
Postby Shadowden » Wed Dec 26, 2012 9:14
I received the GReddy GRacer front lip for AP1s from my wife and her parents for Christmas. I put it on (unpainted) to check fitment and it is spot on.
I like that lip.
Trust/GReddy makes some nice stuff. When I held it, it was very solid. No twisting, flexing/etc. No gaps.
Videos I have seen said to scuff the part with the brown scotchbrite pad, and prime. I would assume an adhesion promoter should be used too, so I am contemplating priming it myself. My brother gave me a LVLP spray gun with the correct nozzle (1.7). Only problem with that plan is my garage is currently dissassembled and I have no room to put up my "paint booth" yet. The other issue, is I really want my stock bumper and this lip to be perfect as it will be the summer/show bumper.
Return to “Piston Vehicle”
Users browsing this forum: No registered users and 45 guests
