Club Install Weekend Apr 16th and 17th
ecam8000
Postby ecam8000 » Fri Apr 15, 2011 9:14
bellalyssa wrote:Does anyone happen to have body panel clips? My sideskirts are coming off near the wheel and I'd like to get them resecured soon so they don't break or completely come off. I need them for both sides of the sideskirt on the front near the wheel.
Thank you!
I have some, various styles. Most are for things like door panels and other trim work. I can get most "dealer" type fasteners/clips if I know what you need.
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
Postby RX-7 Chris » Fri Apr 15, 2011 9:14
ecam8000 wrote:I have some, various styles. Most are for things like door panels and other trim work. I can get most "dealer" type fasteners/clips if I know what you need.
I may show you what I need on my car. The 5 plastic snap in fasteners on the bottom of the front bumper need to be replaced. All the ones they sell at the parts stores are a little off. Mazda wants $5 each for the things.
Postby chickenwafer » Fri Apr 15, 2011 9:14
NAPA usually has a good selection of the body clips (aka speednuts) or the "plastic rivets" Mazda loves to use everywhere. I got all-new speednuts at NAPA when I installed my 99 spec lip as the OEM ones were rusted horribly.
Postby bellalyssa » Fri Apr 15, 2011 9:14
Another thing... does anyone have a headlight restoration kit?
ecam8000
bellalyssa wrote:Another thing... does anyone have a headlight restoration kit?
Yes. I have the permatex "manual" kit. Next time I will try the kit with the buffer wheel that mounts in a drill motor.
Eric
2 Fords 29 & 2000.
99 BMW 328i
ecam8000 wrote:Yes. I have the permatex "manual" kit. Next time I will try the kit with the buffer wheel that mounts in a drill motor.
How well did it work? I've got 7 years worth of crap to get off of my headlights :(
Postby Number2 » Fri Apr 15, 2011 9:14
i'll bring potato salad! :D
I was instructed to ask if you specifically had a press to get the bushings in and out on that bmw.
Ugh.... Men
bellalyssa wrote:I was instructed to ask if you specifically had a press to get the bushings in and out on that bmw.
Ugh.... Men
Is the control arm off the bmw?
Postby iani1.1 » Fri Apr 15, 2011 9:14
hm, i might go. who else in the springs is going?
PXRdriFT
Postby PXRdriFT » Fri Apr 15, 2011 9:14
Chris, Eric and I are going. Pretty early though.
mog1017
Postby mog1017 » Fri Apr 15, 2011 9:14
Would it be okay if I came to replace the valve cover gasket on my NA? The 8 is done for now. Finally got the gauge pod in. But if so, please let me know and let me know what to bring and I will bring whatever. Thanks
Yes the control arm is
ecam8000
I no longer have a press (too much floor space used). I do have ball joint press kit and c-clamps, big vise and creative ways to fabricate tools for specific jobs.
The head light kit works very well, just takes about 20 minutes and some elbow grease!
Eric
2 Fords 29 & 2000.
99 BMW 328i
ecam8000
mog1017 wrote:Would it be okay if I came to replace the valve cover gasket on my NA? The 8 is done for now. Finally got the gauge pod in. But if so, please let me know and let me know what to bring and I will bring whatever. Thanks
NA Miata? Not too tough of a job. Shouldn't be a problem.
Eric
2 Fords 29 & 2000.
99 BMW 328i
Users browsing this forum: Bing [Bot] and 153 guests
