JWT 700BB Twin Turbo 350Z
Have you driven a car with the factory Brembos? If so, how do you like the StopTechs in comparison? I'm looking at buying this Z that doesn't have the Brembos, and would probably upgrade eventually. I loved my Brembos on my G35...but I've heard great things about StopTechs too. They're quite a bit more expensive unfortunately.
Ranger wrote:Have you driven a car with the factory Brembos? If so, how do you like the StopTechs in comparison? I'm looking at buying this Z that doesn't have the Brembos, and would probably upgrade eventually. I loved my Brembos on my G35...but I've heard great things about StopTechs too. They're quite a bit more expensive unfortunately.
I haven't. But during my brake research the factory Brembo's do well on the road course and the OEM non-Brembo's don't. (Trust me!
) Of course any upgrade to a large BBK is an improvement for heat displacement. So if you don't have any/many intentions of taking the Z to a auto-x and/or road course the OEM non-Brembo's will be fine. However I would suggest upgrading to the OEM non-Brembo StopTech Stage II kit. The kit includes; F&R Slotted or Drilled rotors, F&R Axxis Ultimate pads, F&R stailess steel lines, and 3-bottle of Motul DOT4 fluid. I had this kit before my ST BBK and its GREAT for dailt driving!!! Now if you have thoughts of becoming the next SCCA/NASA racing champ I would suggest at least the Brembo's or a BBK. Might want to also consider looking at buying a used set of G37S OEM brakes. They are silver and are at least, if not bigger, than my 4-pot/2-pot StopTechs. Also make note as you go larger on your brake set-up your wheel needs to be larger to clear the caliper. Hope this out you out some. (Personal Opinion: Saved the money you'll be spending for the Z w/ Brembos and purchase a BBK. A front BBK is more than enough braking.)
Won't be tracking it often, if ever. I have another car for the track.
Maybe a few open track days with car clubs, but that's it. I just want a fun second daily driver that I can have fun with in the canyons. That said the factory brakes with a good set of pads and stainless lines would probably work fine for me, but I'll look into a BBK too. Thanks for the info.
Maybe a few open track days with car clubs, but that's it. I just want a fun second daily driver that I can have fun with in the canyons. That said the factory brakes with a good set of pads and stainless lines would probably work fine for me, but I'll look into a BBK too. Thanks for the info.Ranger wrote:Won't be tracking it often, if ever. I have another car for the track.Maybe a few open track days with car clubs, but that's it. I just want a fun second daily driver that I can have fun with in the canyons. That said the factory brakes with a good set of pads and stainless lines would probably work fine for me, but I'll look into a BBK too. Thanks for the info.
If that is your goal I suggest the StopTech Stage II kit for the OEM non-Brembos. You can find this kit for around $600 shipped. Good luck!!!
I assume you will be using all forged internals.
I figured. What is your power goal now?
What about the trans and the rear, will they hold that?
Gallery Belmont Blue Original Dress Up Parts Installed
Thanks to Andy at Performance Nissan. Took awhile to finally receive but I did get them and here are the installed pics. Link to order: MyNismo.com
Users browsing this forum: No registered users and 252 guests
