1970 Ford F250 Explorer
Re: 1970 Ford F250 Explorer
Postby RX-7 Chris » Tue Sep 05, 2017 9:14
I ended up driving out to Peyton yesterday to get a replacement exhaust manifold for the truck. A guy out there is parting out a bunch of 70's ford trucks and he gave it to me for free. I did buy a set of heads for my dad's truck from him for $40.
I hope to get the manifold installed on Friday.
Postby speedjunkie » Wed Sep 06, 2017 9:14
Nice, what a great deal!
And your dad will finally get his truck up and running, just before winter haha.
Postby RX-7 Chris » Thu Sep 07, 2017 9:14
That's the hope although he will still need to have the heads rebuilt since they are 40 years old.
Postby speedjunkie » Thu Sep 07, 2017 9:14
Was that the only problem he had with that engine? After I posted that I was thinking there were problems with the block too but maybe I'm misremembering.
speedjunkie wrote:Was that the only problem he had with that engine? After I posted that I was thinking there were problems with the block too but maybe I'm misremembering.
The shop told him that the block might be cracked but I would be really surprised if that was the case. The Ford FE blocks are hard to kill. The heads can crack between the valves if overheated.
Postby RX-7 Chris » Mon Sep 18, 2017 9:14
I started working on my truck over the weekend. I was installing the exhaust manifold. I got it set in plan and all the bolts started then I climbed underneath the tighten things down. Laying under the truck, I found a black widow web 6" from my head. that ended working on my truck for the weekend, lol. I set off a bug bomb under the hood and pressure washed the underside of the truck.
Postby speedjunkie » Mon Sep 18, 2017 9:14
HAHA
Why didn't you just set the truck and the whole neighborhood on fire? That's the only way you can be really sure.
Postby Huzer » Tue Sep 19, 2017 9:14
Black widows are friendly little suckers. I just relocate them when I find em.
Postby RX-7 Chris » Mon Nov 06, 2017 9:14
I spent the day on Saturday working on the truck. I cleaned up the oil pan and replaced the gasket. I had to raise the motor to get the pan out. When the motor was raised up I found that the motor mounts were original and they fell apart. The previous owner didn't replace the mounts when they swapped the motor. I also started to repair the fiberglass fan shroud. New oil and oil filter are in the truck as well.
To get the motor started:
-Finish getting the exhaust manifold hooked up
-finish the fan shroud
-install upper radiator hose and fill with coolant
-top off the tranny fluid
I'm guessing I have one more day at most to get the truck going. I probably have one to two additional days finish up some of the other projects.
Postby RX-7 Chris » Thu Nov 09, 2017 9:14
I'm hoping to spend some time on the truck tomorrow afternoon so I can get closer to starting it.
Postby RX-7 Chris » Mon Nov 20, 2017 9:14
Being sick and having a sick family has killed most of the truck progress.
I did pull the fiberglass fan shroud and start to repair some cracks and holes. I need to sand the patches and paint it so I can get it put back in.
Postby RX-7 Chris » Tue Dec 05, 2017 9:14
My truck is running. I still have to get the exhaust bolts tighter and figure out the belt squeak. I also need to add tranny fluid.
Return to “Piston Vehicle”
