speed3 only making 10lbs of boost
Brigdh
Postby Brigdh » Mon Jul 01, 2013 9:14
Andyscums wrote:5lbs difference though? That seems pretty crazy. I could understand 2 maybe 3 but holy crap haha
Sounds about right. My 7 is about 4.4 psi off peak.
Bryan08MS3
Postby Bryan08MS3 » Mon Jul 01, 2013 9:14
yea the car still pulls pretty hard, just thought 10 was a little low like i mentioned above. But if thats completely normal for this altitude, thats just something ill have to live with until i can get a AP and DP.
Postby erod550 » Mon Jul 01, 2013 9:14
Is it peaking at 10 and then tapering to like 7 or is it peaking at 12 or 13 and tapering to 10? If it's the former then there might be a problem, if it's the latter then it's completely normal for this altitude. As others have said, reduce restrictions (intake, upgraded intercooler, downpipe) and your boost will go up. You'll also hit fuel cuts at that point unless you are able to raise the thresholds with an AP.
Bryan08MS3
Postby Bryan08MS3 » Tue Jul 02, 2013 9:14
it literally hits 10 and will just stay there all the way to redline. I have always tested it in 3rd or 4th gear as well.
Postby kingtut » Tue Jul 02, 2013 9:14
Bryan08MS3 wrote:it literally hits 10 and will just stay there all the way to redline. I have always tested it in 3rd or 4th gear as well.
This has been my experience as well.
Postby erod550 » Tue Jul 02, 2013 9:14
Yep, sounds normal then. And especially stock or mostly stock, there's really no point in going all the way to redline. Without some mods to remove restrictions it chokes itself out pretty good after 5500.
Bryan08MS3
erod550 wrote:Yep, sounds normal then. And especially stock or mostly stock, there's really no point in going all the way to redline. Without some mods to remove restrictions it chokes itself out pretty good after 5500.
ok, thanks for the tip. I will hopefully be getting Autotech HPFP internals and a DP soon
I'd get an AP before a DP or you will be hating life when you hit that fuel cut and smash your face on the steering wheel, lol. Ok maybe I'm exaggerating a little bit the fuel cut really does suck. A downpipe without a tune can also make you run lean which is no good. If you're going to go stage 2 (DP), the AP is really the first step. They go for around $400 used.
mOOsE
Postby mOOsE » Wed Jul 03, 2013 9:14
I'd keep it stock lol... maybe intake.
Been several people that mod theirs, decide that no traction isn't fun, then sell it. Just a heads up unless you like burnouts :)
Postby geo2maz » Wed Jul 03, 2013 9:14
mOOsE wrote:I'd keep it stock lol... maybe intake.
tru dat, which is why i'm mostly stock except for intake, that and i want to avoid 'da BOOM'!
Postby kingtut » Wed Jul 03, 2013 9:14
geo2maz wrote:tru dat, which is why i'm mostly stock except for intake, that and i want to avoid 'da BOOM'!
I knew you'd come around Geee!
Bryan08MS3
Postby Bryan08MS3 » Wed Jul 03, 2013 9:14
im used to no traction with my civic that goes 10.6 so dont worry, i wont be selling my MS3 anytime soon :)
Postby tsx_guy » Wed Jul 03, 2013 9:14
civic?
Bryan08MS3
tsx_guy wrote:civic?
:confused:
DJ
Postby DJ » Wed Jul 03, 2013 9:14
I love hondas
~David
2008 Mazdaspeed 3 True Red
PTE 5858
JMF intake manifold
Cpe exhaust manifold
2008 Mazdaspeed 3 Cosmic Blue
Users browsing this forum: No registered users and 128 guests
