1970 Ford F250 Explorer
the mouse smell overpowered the oil smell before I drove it back over the mountains. I actually hosed the interior out, lol.
Last night I replaced the fuel sending unit (and pickup), fuel pump, and fuel filter in the work parking lot. I was having a problem with the truck stalling on the way in to work on tuesday. The problem turned out to be the fuel pump even though it was only 4 months old.
I also installed the rear emblems and reflectors. I'll get a pic later.
AIM WO4 wrote:Engine?
I haven't cleaned any of it yet or painted.
I replaced the inner fender on the passenger side because at some point it was almost completely cut out. You can see why I need to rewire the truck.
I had to replace the passenger side door because or was in such bad shape. I still need to finish the rust repair, paint, install trim, and install the mirror.
OLD:
NEW:
OLD:
NEW:
Here is the drivers side door with the holes welded and the factory western mirror:
Here is the Custom emblem and reflector (other side looks the same):
I picked up a chrome front bumper. The chrome is in fairly good shape for its age and will be a huge improvement over the painted bumper. I also picked up pieces I was missing for my sliding rear window. As soon as I get them installed, I will be able to lock and seal my rear window the way ford intended.
I picked up a new rear sliding window seal a week ago and I plan to have it installed this week.
I went to the junk yard on Friday and got a good hood and wiper arms.
3 project vehicles plus a project house, lol.
My truck has been giving me fits all week.
Started out the starter was giving me trouble so I replaced the solenoid. That didn't fix it so I replaced the starter.
After that I replaced the battery because it was dead. The new battery started the truck right up so I thought all was good. Next morning the new battery was dead and the regulator was making noise. I replaced the regulator last night and jumped the car. I went to crank the starter and it stuck on causing the battery terminal to smoke and heat up. I got it all disconnected before I caused a fire. I know there is a short somewhere.
I'm down to:
-Bad new solenoid
-bad ignition switch
-wiring short under the dash
anyone have any ideas?
I'm down to:
-Bad new solenoid
