The mighty green BUG
Postby chickenwafer » Tue May 29, 2012 9:14
^That oil is no good. I would still replace all spark plugs and see if you are still getting misfire CELs. The ignition coils are a notrious failure on these motors so if new, properly gapped plugs doesn't fix the CEL, then it's probably the coils.
gs-panda
Postby gs-panda » Thu May 31, 2012 9:14
chickenwafer wrote:^That oil is no good. I would still replace all spark plugs and see if you are still getting misfire CELs. The ignition coils are a notrious failure on these motors so if new, properly gapped plugs doesn't fix the CEL, then it's probably the coils.
already on it...i bought new gaskets, coil boot plugs, and spark plugs
