MS3 Brakes
Justin
Postby Justin » Wed Nov 09, 2011 9:14
Where are you at? Sounds like you've got lots of help available. It might be a good idea to take someone up on it, just for your own peace of mind.
Postby Learjet45 » Wed Nov 09, 2011 9:14
^^^ IIRC, Alain is more around the cherry creek/glenwood area.
Postby dommo_g » Thu Nov 10, 2011 9:14
GlenDALE?
Postby geo2maz » Sat Nov 12, 2011 9:14
Sweet thanks again everyone,
I just placed the order for front brakes/rotors...
Now, my struts are shot too... and i'm thinking BC Coilovers to replace them, are those a pain to install? It'd make sense to instal those at the same time as the brakes/rotors right?
RichB
Postby RichB » Sat Nov 12, 2011 9:14
Justin wrote:I saw a little less initial bite with Hawk HP-S pads and actually liked the stock ones better for daily driving.
Really? After my Hawks were seated and broken in I thought they had way more bite than the stock pads.
SecondGenPAt
Postby SecondGenPAt » Sat Nov 12, 2011 9:14
Hey Alain, let me know if you need help with the repair. Brakes are easy and I have to correct tools to do the job.
-Pat
Justin
Postby Justin » Sun Nov 13, 2011 9:14
RichB wrote:Really? After my Hawks were seated and broken in I thought they had way more bite than the stock pads.
Yeah, it was weird. They seemed to have less initial bite, then warm up after 10-15 feet and grab harder. I'd find myself hitting the brakes, then letting up a little after the initial grab. I still like them just fine, just different than stock. They still stop like crazy and seemed a little easier to modulate.
Postby erod550 » Mon Nov 14, 2011 9:14
Justin wrote:Yeah, it was weird. They seemed to have less initial bite, then warm up after 10-15 feet and grab harder. I'd find myself hitting the brakes, then letting up a little after the initial grab. I still like them just fine, just different than stock. They still stop like crazy and seemed a little easier to modulate.
I haven't run Hawk pads yet but plan to next year. From what I understand this behavior is to be expected. The Hawk pads are much more effective, but need to be a little warm first, so you lose a little initial bite because they're not yet warmed up. But once they are warm, they brake much better than normal pads. That's why they're good at the track, because they get warm and stay warm, whereas on the street you're not usually on the brakes heavily a lot, so they don't stay warmed up as easily.
RichB
Postby RichB » Tue Nov 15, 2011 9:14
Maybe I haven't noticed the initial bite because I rarely brake without downshifting also....
Postby geo2maz » Wed Nov 23, 2011 9:14
Does anyone know of a reliable local place that sells MS3 brakes/rotors?
I placed my order on tire-rack for both several weeks ago, brakes are in stock, rotors weren't, that was my fault bc i didn't notice the rotors were out of stock... so i changed the order to slightly higher-priced rotors that were listed in-stock, only to find out they are out of stock too. Running out of patience, if I can get them local at the same price, i'll do that and cancel the order... Lemme know, thnx
Postby kingtut » Wed Nov 23, 2011 9:14
JP @ Edge Autosport?
Justin
Postby Justin » Wed Nov 23, 2011 9:14
You shouldn't need new rotors. Just have them turned. A parts store can check spec and turn them for you. Probably be about ~$20 each. Depending on mileage, your rears should be fine.
D Walker
Postby D Walker » Wed Nov 23, 2011 9:14
it is usually unwise to turn modern rotors, they are pretty thin to start with and once worn should just be replaced.
Postby geo2maz » Thu Nov 24, 2011 9:14
The dealership told me the same thing, that they are too thin to machine.... Car has about 48k on it now..
I checked Edge and that's a good option, but a lil higher-end than what I was looking for.
Postby kingtut » Thu Nov 24, 2011 9:14
Users browsing this forum: Bing [Bot] and 225 guests
