Gtx3071
RichB
Postby RichB » Tue Oct 25, 2011 9:14
Hmm, it looks like it may need to be extended some more but I may be wrong. Also, anyone know which DPs cause interference issues? I know the ATP DP works (for obvious reasons) but am not sure about any others.
RichB
Never mind. The wastegate would be on the bottom. The dump tube shown should be long enough. Still not sure about DP interference though.
dsm_luck
Postby dsm_luck » Tue Oct 25, 2011 9:14
RichB wrote:sweet.
What's the dump tube look like and where does it exit? I would definitely want to go EWG but the fab that is needed for the dump tube worries me. The only way I can think of getting it done is to drive to a shop after I install the turbo w/o hitting boost to get one fabbed up. Since I have a hard time staying out of boost, this isn't ideal.
Your EWG will not open until the preset boost is hit. You can actually set this before you put it on the car by pressurizing it. Most people set it to somewhere in the mid to high teens. On mine the WG is set to as low as possible and still opens at 10 psi. You would be able to drive around on a BT to get to a shop just fine. Trust me the boost build much more linear on a BT.
dsm_luck
COSpeed3 wrote:what r u running for ur inlet?
Yes, JP has some great prices...
I picked up a used CPE BT inlet. Thing is a piece of crap and took 3 hours to get on. It works fine now though.
RichB
The only other inlet option is the ATP one and I don't even know what it really looks like.
COSpeed3
Postby COSpeed3 » Wed Oct 26, 2011 9:14
RichB wrote:The only other inlet option is the ATP one and I don't even know what it really looks like.
What doesn’t make any since to me... the only differences between the CP-E BT inlet and stock Turbo inlet is the coupler on the turbo side? Why can’t I just use my inlet and find a coupler with a 4" end for the turbo side?
Cobb–Access PORT
Cork Sport-FMIC,Intake,Inlet
Edge-Insight CS Scan Tool
Innovate-LC1 Wideband Gauge
Luminics-Fog,High Beams
RPM-Vent Pod
Turbo Smart-Dual Port BOV
Turbo XS-TBE[/SIZE]
RichB
Postby RichB » Wed Oct 26, 2011 9:14
because the stock coupler and inlet are one piece. If it was set-up like the HTP Turbo Inlet, you could just swap the out the couplers.
COSpeed3
RichB wrote:because the stock coupler and inlet are one piece. If it was set-up like the HTP Turbo Inlet, you could just swap the out the couplers.
thats what i'm saying. my inlet has the pipe and a coupler, i would think i could get alway with just changing my coupler and save me $200
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
RichB
Ah, you have a corksport. You should just be able to get a coupler then...
COSpeed3
Rich are you going BT also?
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
RichB
Not until I have the funds which will be a while (maybe years). I'll have a plan in place though :-)
dsm_luck
Postby dsm_luck » Thu Oct 27, 2011 9:14
COSpeed3 wrote:thats what i'm saying. my inlet has the pipe and a coupler, i would think i could get alway with just changing my coupler and save me $200
I thought about that path when I did the install but I was told that the turbo inlet is slightly lower on the 307X than the k04 due to its size. This prompted me to pick one up used for $100.
RichB
Postby RichB » Thu Oct 27, 2011 9:14
I don't think GoSpeed has that option with the Corksport kit. I may be wrong.....
COSpeed3
Postby COSpeed3 » Wed Nov 02, 2011 9:14
just ordered the GTX3071r and FP Internals
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
RichB
Postby RichB » Wed Nov 02, 2011 9:14
Nice!
Good luck with the install.
Users browsing this forum: No registered users and 143 guests
