First Car To Die On The Way To A Meet
Laurel
Laurel
Thanks for the help.
OK I am figuring things out with my car. My goal is to make my car better on the track but still keep it a street car. I would like to be able to beat my dad in his car. These are his specs.
'70 Porsche 911 2.2L Targa yellow (I will get a Pic)
HP at the wheels 142
LB at wheels 135 with pretty good power band
The car starts to pull good over 3k, it is not a good autocross car.
The gearing is almost identical to the RX-7 although the trans can not be shifted that fast.
Best track time at pueblo was 1:55.930 (average 2:00)
he has a rollbar in it now and will be putting a cage in it soon. Because it is a targa, it flexes real bad and the cage will fix that. If you jack up one tire, the doors will not open.
It is fairly good in the turns unless you lift off the throttle in a turn that is has serious oversteer.
The car is about 2300 LB.
I know this goal is realalistic. He is always talking about my car like it is an old junker. I want my old junker to kill his fancy sports car.
I will be putting a streetport 12A w/ a holley 465 streetport setup. You can see the list of what I have already in my sig.
What kind of streetport should I do, mild or better? I would like to have some LB as low as realistic.
Any ideas on what I can do? my $$ are limited beyond the motor and carb right now.
<div class='quotetop'>QUOTE (RX-7 Chris @ Jan 18 2008, 09:39 AM) [url=index.php?act=findpost&pid=19165]<{POST_SNAPBACK}>[/url]</div>
wouldn't it be easier to take a bat to your old man or his car? or is that cheating j/k....
Any ideas on what I can do? my $$ are limited beyond the motor and carb right now.[/b]
<div class='quotetop'>QUOTE (Laurel @ Jan 18 2008, 04:01 PM) [url=index.php?act=findpost&pid=19273]<{POST_SNAPBACK}>[/url]</div>
... and Fords, Chevies, Dodges... LOL I used to adjust mine at least every 6 months. I finally swapped for a Carter... back in the days of the leaky Holly double pumper.btw i've heard that holly carbs don't stay tuned well. but that was on a 240z.[/b]
- goldrocket
I't's not that Holley carbs don't stay tuned, they just aren't all that accurate, and when atmospheric conditions change carbs don't, hence the lack of consistent performance. That's also why it's good to go to fuel injection! It keeps the fuel mixture pretty much set all the time. As soon as possible I plan to built and EFI for my heap..
Chris, I have a radically street ported engine and it idles fine and drivability is great. Once it warms up and the metered fuel leaks are working good, it will idle at 800 RPM. Keep in mind when an engine is ported, the power band moves up in the RPM range. Mine makes all its power above 5500 RPM. On a track it's not hard to keep it there, so I can stay in my power range pretty easily. there are a couple folks on Mazspeed.com that are running half-bridge engines. that's when the two inner ports are stock aside from some polishing, and the outer ports are bridge ported. According to the guy that is a moderator who has one of those engines, he has smooth idle and a broad power range. He is also running a 13B. If you are going to keep your 12A I would definately go with either a large street port or a half bridge. But make sure you upgrade your apex seals either way.
Al says
So I have desided to use Rotary Warehouse. I talked to them about questions I had an I will be ordering the motor on Monday. I will be using there streetport setup. As for holley carbs, that is what I have on every other car I own and I can tune one in about 5 min. with 1 screwdriver. I know them well and have rebuilt my share.
Thanks for the input Goldrocket.
Rotary Warehouse said it would take 2 weeks to build and 4-5 days to ship.
Does anyone have a cherry picker that I could use? My dad has one but it is in GJ and I don't know when I could get it over here.
- goldrocket
<div class='quotetop'>QUOTE (Greek8 @ Jan 19 2008, 07:38 PM) [url=index.php?act=findpost&pid=19387]<{POST_SNAPBACK}>[/url]</div>
Advocate violence against me and try to put me to work? Geez Greek you're on a downhill slide...
If you can't get one just get 3 other guys from the springs, hook up the chains and lift it out.[/b]
Mods:
Mods:
Users browsing this forum: No registered users and 122 guests
