For Sale or trade 1991 miata 3300 OBO
- Dange
I have a daily driven turbo miata that WILL actually outrun most fwd and awd cars around here... so i know a lower powered miata can do it no problem because I have to be careful when the turbo spools because of the sudden increase in power.. and i dont even have snow tires...
daily driven meaning blizzard conditions, i turn on the foglights and just go where i need to go. and get weird looks from soccermoms in their suvs while i pass them.
people complain about rwd. but the only benefit FWD/AWD have in the snow and ice is starting from a stop up a hill. otherwise stopping traction and turning are identical.
04MSMGT
borisovich
- Member
- MazdaSweet3
haha boris! whats up!!? its joe from k soops. Dude u go through cars like juicy fruit gum. Just keep the damn thing! Be one of us mazda folk
Cp-e Nano SRI
Cp-e CBE
SU rear engine mount
SU test pipe
Cobb turbo inlet
Cobb Access Port
Turbosmart BPV
[SIGPIC][/SIGPIC] more coming soon..............
Cp-e CBE
SU test pipe
Cobb turbo inlet
Cobb Access Port
Turbosmart BPV
borisovich
- Member
Dange wrote:I have a daily driven turbo miata that WILL actually outrun most fwd and awd cars around here... so i know a lower powered miata can do it no problem because I have to be careful when the turbo spools because of the sudden increase in power.. and i dont even have snow tires...
thankyou! Also most people that say rwd is bad on snow have never actually driven on snow with a rwd. My rx7 with all season tires handled better than my dads fwd car on worn winter tires.
- Dange
exactly, even with all seasons on the miata, In order to slide I usually have to purposely get sideways except for a worst case scenario and even then i can maintain the slide almost full lock around turns in perfect control with just some throttle modulation. lighter throttle to bring the tail back or more throttle to push it out more.
the real issue is getting out of a parking lot when the tires are frozen into grooves. or starting moving UP a hill from a stop.
YES fwd is sometimes better for a novice driver to correct a spin because you just point the wheels where you want to go and pin it. (ill post a awesome video from a BTCC race I saw that shows this in the funny vids section.)
But seriously, find an EMPTY parking lot with no curbs, and practice entering an exiting a slide next time it snows and freezes. if you're not acting like a hoon and doing doughnuts or actively drifing and a cop pulls up explain to him and they will either let you continue or just tell you to move on.
Just practice some throttle modulation (usually just letting off of the pedal is enough) and steering when in a slide to recover, and brake modulation when coming to a stop so you dont lock up the tires. WORST thing you can do in any situation is slam on the brakes, which is most peoples first instinct. because as soon as the tires are locked up you went from minor traction and some steering to absolutely no traction or steering. and you are suddenly an out of control 2000lb projectile.
once you have it down, itll help you alot when the weather gets really bad.
I'm not saying an awd or fwd car with studded snow tires isnt a bit better on ice all with all other things equal. my buddies speed6 can pass me up the hill no problem while i sit and fight the spinning.. but i am saying its not required nor a good idea to sell a good running fun car and spend even more money for a car that you have no idea the issues with. just invest in some snow tires, skill and practice which you should get for any car anyway.
04MSMGT
