my austrian rx-7 fc
323Bf
Postby 323Bf » Sat Oct 02, 2010 9:14
i have one big problem. the pre owner have said, that the 2nd rotor have water inside. the engine smokes white and we always must do water inside... whatg can be broken???
He said, that a hairline crack is the reason...
What you felix wankels said??????????
Thanx for help :confused:
http://www.mazdascene.at
http://www.pernull-racing.at
Postby Ranger » Sat Oct 02, 2010 9:14
It could be anything. Unfortunately, as simple as the rotary engine is, it's very hard to troubleshoot without tearing down the entire engine. Most likely just corner seals need to be replaced, but it could be that the housing is cracked. Check out this page:
http://www.rotaryresurrection.com/rotary%20pages/internaldamage%20folder/internaldamage.html
Postby chickenwafer » Sat Oct 02, 2010 9:14
If the motor has white smoke and you need to top off the coolant, then you're burning coolant. Most likely you have a blown coolant seal, which means a complete rebuild.
323Bf
Postby 323Bf » Sun Oct 03, 2010 9:14
i think that i must rebuild the engine... But i think, i must take the engine to pieces to see the real damage....
hmm, and i don´t get some spare parts here in austria...
i must order 95% in the usa....
Users browsing this forum: Baidu [Spider] and 86 guests
