RPM Street Spings.....
Gmoney
Postby Gmoney » Fri Mar 13, 2009 9:14
303native wrote:Are the RPM Streets an even drop all around, or are they a little lower in the front?
My springs have not fully settled, but thus far it is exactly what I wanted a even drop. They claim 1.1 up front and .75 in back and so far it is right on...you can see in the pics it looks almost the same front to back......lovin them right now, makes the look I have been shooting for awhile.......finally
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
Gmoney
Regulator wrote:Where were you when I was paying to have mine installed! I would have rather done it on my own and gained some knowledge, but I didn't have any of the tools :(
Anyways... Still wanna see the pics of the ride
I have always been here......just had so many new/old house projects holding me hostage......wish I could of helped, I have lots of tools, just not sure where they all are right now....:confused:
Feel free to hit me up with your next item of duty.......:D
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Postby ~Barn~ » Fri Mar 13, 2009 9:14
If you're seriously down to do it again, let me know. I'm not going to probably learn much, unlike Regulator, but I'll "hold the flashlight" or whatever. I'll give you two 6-packs per hour! =)
Gmoney
~Barn~ wrote:If you're seriously down to do it again, let me know. I'm not going to probably learn much, unlike Regulator, but I'll "hold the flashlight" or whatever. I'll give you two 6-packs per hour! =)
Let me know.........I can work it out with my work schedule........I was just kidding about the beer, though it does pass the time better
Can take what I learned from mine and am sure I could do it again in a more timely manner.
With two 6 pks/hr could use some spectators.....:)
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Seriously! I don't want to start inviting people to your place, but if Regulator wanted to come watch, I guess this is a chance. Ha!
Okay... So before I get too over-my-head with commitments here, lemme say that it's realisticaly a toss up between a cold air intake, and springs. If I do get the CAI, it'll be my first mod in the performance realm, and from what I hear, they take-well to the MS6, so....
Anyway, lemme think about this all. And would you mind helping me with that install of a CAI, for that same "beer rate"? =)
I feel like a chump for not knowing how to work on my car, but it is what it is.
bobopud
Postby bobopud » Sat Mar 14, 2009 9:14
Don't feel bad about not knowing your car. Everyone started out that way and had to learn it over time. You were just giving everyone else a head start.
I feel like I should have some sort of a degree with how much research and homework I have donw with this car. It is nice to know that if something does come up I can fix it, or have this community to help me out.
Postby MazdaTom » Sat Mar 14, 2009 9:14
I'd be down for a spring install. Suspension work is fun. I've done springs on several cars.
cprtrainer
Postby cprtrainer » Sat Mar 14, 2009 9:14
Never done it, would like the same springs on my MS6. I think we should do a "suspension meet" sometime before summer. Install, beer, food... not necessarily in that order...
Postby tsx_guy » Sat Mar 14, 2009 9:14
did we determine if a camber kit is needed?
Gmoney
Postby Gmoney » Sat Mar 14, 2009 9:14
6i_guy wrote:did we determine if a camber kit is needed?
Not yet I will be going to get an alignment in a couple weeks when the springs settle in......will let you know what they say
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Gmoney
bobopud wrote:Don't feel bad about not knowing your car. Everyone started out that way and had to learn it over time. You were just giving everyone else a head start.
+1 on that point
I would have no problem helping out with either.......
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Postby tsx_guy » Sun Mar 15, 2009 9:14
lemme know about the camber kit. At my recent alignment they were only able to do so because of the OEM components.
Regulator
Postby Regulator » Sun Mar 15, 2009 9:14
Just throwing it out there... If you are going to get springs installed and also need a new set of tires... discount tire will give you a free alignment when you buy a set of tires from them.
Postby tsx_guy » Tue Mar 17, 2009 9:14
i was not offered said alignment during my last purchase (mad)
just realized RPM does not make springs from the 6i....
