Wish me luck...
Postby AIM WO4 » Thu Jan 22, 2009 9:14
I'm not sure where some of the Mazda parts are made these days, but some European cars go into "limp home" mode which resets after the car is shut down and restarted. My Saab had to be manually reset.
The ECUs are probably based on the same crap coming out of Germany as well. I have also seen some reports of ABS modules going bad on Mazdas prior to warranties expiring. I think it's all a part of the "new" electronic way of doing things. I'd like to go back to cables and vacuum actuation if it would save me the headaches.
:D
Renesis Rx wrote:Got my car back from the dealership today and they couldnt find anything wrong with it. Said everything checked out ok and they couldnt duplicate any of the problems. Just gotta keep my eye on it and hope it was nothing. Cool thing though, they reflashed my PCM. Said to many customers were complaining about a lack of power. Just the short time i drove it since, I can see a big difference. Maybe thats all it needed.
Did you have any codes? Do you have an OBD II code reader?
Renesis Rx wrote:Yeah I feel the same way. How do you say that it probably needs a new engine then say there's nothing wrong but we reprogramed your computer for you. Like I said it does feel better driving it, but I haven't gotten on it yet. I'll have to take it on I-25 and see how it does.
METHLAB
Postby METHLAB » Thu Jan 22, 2009 9:14
Any update?
Renesis Rx
Postby Renesis Rx » Thu Jan 22, 2009 9:14
AIM WO4 wrote:Did you have any codes? Do you have an OBD II code reader?
No it wasn't putting off any codes. No CEL or anything. It was just running like crap. No I don't have a reader.
METHLAB wrote:Any update?
Didn't get a chance to run it hard today but it was still idling rough at 6 to 7 hundred RPM. Felt a bit low. I remeber it use to idle right between 900 to 1000 rpm.
Renesis...MMMMMMMMM
Postby AIM WO4 » Fri Jan 23, 2009 9:14
That's very odd. I guess I'll have to get a rotary someday in order to understand probable causes.
If you have the $$, you can get a Dashhawk for cheap. You could use that to diagnose as you drive.
Postby RX-7 Chris » Fri Jan 23, 2009 9:14
can't you take it to autozone or checker and have them read it for free?
Renesis Rx
Postby Renesis Rx » Fri Jan 23, 2009 9:14
I could try that. Would it still give a reading without a check engine light?
Renesis...MMMMMMMMM
Postby RX-7 Chris » Mon Jan 26, 2009 9:14
no idea.
Users browsing this forum: No registered users and 122 guests
