I'm so excited
Postby GR-8 » Fri Oct 03, 2008 9:14
LOL @ Gold
Huzer21 wrote:Sure, just let me know when. Question, is the notchiness still there after the car warms up? Mine is a little bit when cold, but gets better. I'm thinking of swapping the fluid.
And yes the notchiness is still there after it's warmed up. I mean it goes it niceley.....I cant feel the baby grinds I used to when getting into seocond but in every gear there is that notchiness push back feeling likee it doesn't want to go in. I will be calling McDonald monday after I get a chance to drive yours Tim. I remember when it used to just glide into gear with little effort. Glad the grinding is gone but still warranty is almost up and I want it to be perfect.
so.....i found out about why the car was not starting up right and why i had to crank it for a while....the freeaking plug wire was off of the rear rotor all the way on the bottom. i couldnt get to it from up top since i had the motor running for a couple mins while i checked what the CSEL was for....so i poped the wheel off and snapped it back on.
well the gear shifts are notchy still.....in all gears almost. even when the car is warmed up. when first getting into gear i get a kickback. weee.
tim i get off work @ 3 sunday and monday. mebe i can come test yours sometime then? will u be @ the sonic meet?
Postby Huzer21 » Fri Oct 03, 2008 9:14
I'll be around Sunday. I start on-call on Monday, so that might be iffy. If the weather's nice, I'll swing by Sonic on Sunday...what time do you usually get there?
Postby Huzer21 » Sun Oct 05, 2008 9:14
I can't make it out to Sonic tonight. I'll be home from work around 4 PM tomorrow, so I should be around any time after that. You can pm for address/number if you want to stop by.
Postby GR-8 » Tue Oct 07, 2008 9:14
Soooo.....Update.....Yesterday I met with Tim before going to the dealer again to test drive his. It had the same notchyness as mine only less of it.......The clutch also felt a lot better than mine.....mine felt like his for about 3 days after getting it back then it was like it was gone.
So anywho.......I just now got it back and the clutch is better...they fixed the CEL...some connection was loose in a wire so they repaired that.......The notchyness is slightly there.....Like Tims from what I recall. The clunking when getting into first or shifting.....usually into third is there but better. We will see in the following week.....
A thanks goes out to Mcdonald for being quick and listening and diagnosing things right away. +1
Users browsing this forum: No registered users and 82 guests
