My 1982 GS project thread
- Low Impedance
since i am going to have to drop the fuel tank here soon and see why the pump is getting no fuel, lets talk about a future upgrade i am planning!
The transmission replacement!
The stock rx7 transmission has some piss poor gear selection. The stock 12a gearbox is shown below.
3.674 (1st) 2.217 (2nd) 1.432 (3rd) 1.00 (4th) 0.825 (5th)
The spread does not take advantage of what the engine can really do. For the sake of my build, the Mazda Comp Manual PDF (see the FAQ) has some good information on the Mazda Competition Transmission. If you want one...well that sucks because your looking for a surviving used one.
BUT the information i did get from the PDF is the gear selection of the comp. transmission.
2.350 (1st) 1.608 (2nd) 1.240 (3rd) 1.00 (4th) 0.881 or 0.839 (5th)
This information is priceless for the sack of want to do. As a bonus, that setup was used with the 4.88 final drive and a 12 PP. Ill be running a 4.78 with a 13b Bridgeport. So i am close to that the "perfect" setup would be.
So why does it matter that i know the ratios of a transmission i cant buy anymore? Well thanks to people with more time and money than i have, there are bell housings and other adapters to run other transmissions on the Mazda Rotary.
The transmission i want to use, if i can find an adapter for the GM 1-1/8" 26 spline, is the Richmond Gear Super T10 with the 2.43 (1st) 1.61 (2nd) 1.23 (3rd) 1.00 (4th) non overdrive and is only about 1500 dollars.
The ratios are very very close to the Mazda Comp.
But i dont know of a GM adapter, ill have to look, but if i cant find one, the option for the Ford T5 adapter exists.
The ratios for the Richmond Gear Super Street 5spd are:
2.89 (1st) 1.85 (2nd) 1.31 (3rd) 1.00 (4th) 0.77 (5th)
OR there is also the Richmond Gear 4+1 5pd with
3.27, 4.06, or 4.41 (1st) 2.13 (2nd) 1.57 (3rd) 1.23 (4th) 1.1 (5th)
I do not like that setup for one reason, first gear is useless with a 4.78.
I think i need to call Summit and see what other options not listed in the catalog are....
I'm going to post here.
If you want to get that tank real clean this is how you do it:
Drop the tank, remove anything that might be rubber, plastic, or aluminum. Buy some lye at the grocery store (they sell it to clean septic tanks). Pour some water in the tank and the container of lye. shake the tank around and let it sit for a bit. Do not get this stuff on your skin or eyes. Then drain the tank and rinse it out with fresh water. the inside of the tank will be like new. now put it all back together and reinstall.
Do not do this on aluminum or plastic tanks.
As for transmission, I would go with the miata setup.
- Low Impedance
RX-7 Chris wrote:I'm going to post here.
well i guess it will give me something to do this weekend...
- Low Impedance
RX-7 Chris wrote:As for transmission, I would go with the miata setup.
as for the miata transmission here is what i found
Ratios:
1st 3.136
2nd 1.888
3rd 1.330
4th 1.000
5th 0.814
Final Drive 4.300
5th 0.814
Final Drive 4.300
That is basically a split between the stock rx7 and the mazda comp transmission. I think i need to go talk to some people who have been racing with these ratios and get some advice.
I know it isn't as good as the comp setup but it is a lot cheaper and a fairly easy change over.
- Low Impedance
- Low Impedance
someone referred me to here:
http://www.awrracing.com/store/product_info.php?products_id=395
to the tune of 2800 dollars...
New 5-Speed Quaife Synchromesh Gearkits for Mazda Miata and RX7. Heavy Duty, semi-helical, close ratio gearsets are available in two configurations for both performance street and race applications. Available for 1.6 and 1.8 Miata and RX7. Quaife 5 speed Gearset for 1990-2005 Miata and 1981-1992 RX-7. Also fits 2006-2007 MX-5 5 speed box with slight modification. Available in two different ratio sets. Installation is available by AWR for $595.00.
RATIO SET 2 2.350 1.550 1.240 1.000 0.886
- Low Impedance
so the miata box and the rx7 box STILL have the same 1st to 2nd shift lump with about a 3800 rpm drop. but the 2 - 3 - 4 is much better....
i think the best overall though is the Richmond Gear Super Street
The drops are never below 6100 rpms and the 5th gear would still leave a 3800 rpm engine speed while cruising at 70 mph...
if i want to not worry about the freeway ever, then i think i would opt for the Richmond Gear 4+1 but the 5th gear 1.1 ratio and a 70 mph engine speed of almost 5500 rpms is a turn off to that.
The T10 box might be slighly better, but there is no overdrive gear and the difference isnt that big between the Super Street and itself.... Ill have to check its other ratio combinations to see if anything can be gained
- Low Impedance
Here is the data i processed:
I used an assumed shift point of about 9600 rpms. The true shift point may be lower (about 9000) once i finish my engine build, but generally, this gets the point across.
Mazda 12a Gearbox w/ 4.78 Final Drive on 205/50 R15 Tires
9600 rpm shift point (assuming bridge ported engine)
70mph = 4136 rpm
*Top gear yields 16.9 MPH / 1000 rpms and top speed of 162.5 mph ( @ 9600 rpms)
*Top speed in 1st gear = 36.48 mph
-Changes into 2nd gear at 5793 rpm dropping 3807 rpm
*Top speed in 2nd gear = 60.45 mph
-Changes into 3rd gear at 6201 rpm dropping 3399 rpm
*Top speed in 3rd gear = 93.60 mph
-Changes into 4th gear at 6704 rpm dropping 2896 rpm
*Top speed in 4th gear = 134.035 mph
-Changes into 5th gear at 7920 rpm dropping 1680 rpm
*Top speed in 5th gear = 162.467 mph
Mazda Miata Gearbox w/ 4.78 Final Drive on 205/50 R15 Tires
9600 rpm shift point (assuming bridge ported engine)\
70 mph = 4081 rpm
*Top gear yields 17.152 MPH / 1000 rpms and top speed of 164.662 mph ( @ 9600 rpms)
*Top speed in 1st gear = 42.74 mph
-Changes into 2nd gear at 5780 rpm dropping 3820 rpm
*Top speed in 2nd gear = 70.993 mph
-Changes into 3rd gear at 6763 rpm dropping 2837 rpm
*Top speed in 3rd gear = 100.778 mph
-Changes into 4th gear at 7218 rpm dropping 2382 rpm
-Changes into 5th gear at 7814 rpm dropping 1786 rpm
*Top speed in 5th gear = 164.662 mph
Richmond Gear Super Street w/ 4.78 Final Drive on 205/50 R15 Tires
70 mph = 3860 rpms
*Top gear yields 18.12 MPH / 1000 rpms and top speed of 174.071 mph ( @ 9600 rpms)
*Top speed in 1st gear = 46.379 mph
-Changes into 2nd gear at 6145 rpm dropping 3455 rpm
*Top speed in 2nd gear = 72.451 mph
-Changes into 3rd gear at 6798 rpm dropping 2802 rpm
*Top speed in 3rd gear = 102.317 mph
-Changes into 4th gear at 7328 rpm dropping 2272 rpm
-Changes into 5th gear at 7392 rpm dropping 2208 rpm
*Top speed in 5th gear = 174.071 mph
Richmond Gear 4+1 5spd w/ 4.78 Final Drive on 205/50 R15 Tires
70 mph = 5515 rpms
*Top gear yields 12.693 MPH / 1000 rpms and top speed of 121.85 mph ( @ 9600 rpms)
*Top speed in 1st gear = 40.989 mph
-Changes into 2nd gear at 6253 rpm dropping 3347 rpm
*Top speed in 2nd gear = 62.927 mph
-Changes into 3rd gear at 7076 rpm dropping 2524 rpm
*Top speed in 3rd gear = 85.373 mph
-Changes into 4th gear at 7521 rpm dropping 2079 rpm
*Top speed in 4th gear = 108.972 mph
-Changes into 5th gear at 8585 rpm dropping 1015 rpm
*Top speed in 5th gear = 121.85 mph
70mph = 4136 rpm
70 mph = 4081 rpm
70 mph = 3860 rpms
70 mph = 5515 rpms
I think I will be going with the miata setup.
Why are you shifting at around 6k into second?
- Low Impedance
With my streetport it does best if I shift around 7k into second. My engine is a large street port, about as big as you can go.
- Low Impedance
From second to third I shift at about 8k. my motor is setup to reline at 9k but the power drops after 8k.
I'm running 195s.
I'm running 195s.
