new parts
goldrocket
Postby goldrocket » Wed Aug 06, 2008 9:14
The best map you can get is one that has been tuned in your car while it's on the dyno. Maps are great, but every car is going to be a little bit different. You'd be amazed at the difference in mileage and performance when you get that done. My car is stil blessed with anitquated junk for an induction system(Carburetors), but I went from 16mpg in the city on a good day when I never hit the secondaries, to 18 mpg in the city, and I get to have a little fun driving it at that. Plus i got 14 more horsepower by taking the time to tune it across the rpm range. When you get your exhaust, then get it on a dyno and have it tuned. when the fuel and timing are dialed in by rpm increments, the car will be a lot smoother, more powerful, and use less fuel. It's well worth it. My a/f stays close to 13 across the board, except where the carbs transfer from primary to secondary circuits. That's where mine made the best power. It was real fat in some places and way too lean inothers before we tuned it. i did mine at SR-Tuning. Frank can plug into your cars ecu service port and monitor everything your car is doing, and he uses high dollar Lambda sensors in the exhaust to measure the af ratio. And he can make ECU adjustments in real time while you run the car on the dyno. So he can watch af ratios, temps, timing, and up to 40 sensors to get it dialed in so tight you'll think you're driving a different car when it's done.
Al says
Postby GR-8 » Wed Aug 06, 2008 9:14
That's true. But I don't really see the gain in dyno tuning the 8 if it's just NA. I know that it's better but can't see spending the money when you won't gain to much more than the free custom maps that MazdaManiac will tweak for you. The next best thing to dyno tunning is is sending MM data logs throught most of the gears. He can change so much more than just telling him it's bogging here or the AFR at X RPM is this. Still doesn't beat dyno tuning but if it's free use it. If you have the money go for the dyno tune.....I know if I had the money I'd dyno tune it. Heck if I had the AP still when Steve Kahn was here and I had $400 I woulda dyno tuned it that day I got dyno'ed.
cory.sparks
Postby cory.sparks » Tue Aug 26, 2008 9:14
Wow you guys know your stuff who can I go to to help me out with all this ECU's and acsses ports and everything because I wanna buy some sweet stuff but dont know what is good or not.
