MazdaSpeed Fuel pump bulletin
Gmoney
Postby Gmoney » Fri Jun 13, 2008 9:14
<div class='quotetop'>QUOTE (Korben Dallas @ Apr 28 2008, 08:21 PM) [url=index.php?act=findpost&pid=43360]<{POST_SNAPBACK}>[/url]</div>
FYI, my Speed6 threw a CEL this weekend and had it checked out this morning. Lean mix warning error resulting from low fuel pressure, they are following this TSB procedure. I was not driving hard when this occurred and did not experience any odd running characteristics.
The car did have an inconsistent idle and what I would describe as inconsistent power in 2nd and 3rd between 3k and 4.5k RPM while under load and the turbo spun up.
Currently, the replacement pump is on order. I will post more if I learn anything else.[/b]
Can you post on whether your repair fixed the problem, my MS6 has a rough idle when warm drops to like 650rpm and then back up to 900rpm consistantly at a stop light. When cold idles perfect at like 800rpm. I am to seeing a power lull in the 2nd and 3rd pull, can hear the turbo screaming just not feeling it.....Thanks for your input........G
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
mazdaman-G-
Postby mazdaman-G- » Sat Jun 14, 2008 9:14
<div class='quotetop'>QUOTE (GMoney @ Jun 13 2008, 11:25 PM) [url=index.php?act=findpost&pid=52042]<{POST_SNAPBACK}>[/url]</div>
Can you post on whether your repair fixed the problem, my MS6 has a rough idle when warm drops to like 650rpm and then back up to 900rpm consistantly at a stop light. When cold idles perfect at like 800rpm. I am to seeing a power lull in the 2nd and 3rd pull, can hear the turbo screaming just not feeling it.....Thanks for your input........G[/b]
It did fix the problem and it's made a big difference, the car is smooth all the way through the RPM range now. Before it was replaced I noticed the problem in 3rd the most, the car often felt jerky like you were short shifting but that's no longer the case. Good luck, I hope it works for your car as well.
-G-
EvoXGuy
Postby EvoXGuy » Sat Jun 14, 2008 9:14
You see a drop in power due to the pump running out of fule due to its inefficiency. So what happens is the sensor after the fuel pump tells the computer to close the throttle plate. That is were the power lose comes from just some info I thought I would put out there.
Gmoney
Postby Gmoney » Sat Jun 14, 2008 9:14
Well I guess when I get my car back next week I will be switching out parts to stock and back to mcdonald's to see if this is my problem as well. Thanks for the info.......Greg
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
