Think you can take me now Eric?
I'm with RMSpeed6... lower IAT's should give you more power in theory, if your car was NA, in theory, you should have lost power (even if only a negligible amount) ... but then again, there's more to it than that on a turbo car, seeing how the ambient air from the intake is sucked into the turbo, where's it's compressed, which heats it significantly, and is then routed through the intercooler where it's cooled significantly.... some say, on a turbo car, the efficiency of your intercooler is FAR more important than the placement of your intake filter.
Although, with less piping, SRI's typically give slightly better throttle response. Extra power felt could be attributed to a number of things, especially with the MS6's timing crazy ECU. Odd that you would see an increase in boost though... if you're seeing almost 1psi of extra boost, there's no doubt, the extra power you're feeling didn't come from the SRI directly, it came from the extra boost the wastegate isn't bleeding off/turbo is pushing. Did you reset the ECU? What are you running for boost control? Any engine management device? If you're running a stock ECU, no boost control it might just be the BCS trying to readjust itself for the changes in the amount of piping that has to be charged by ambient air being drawn into the compressor housing?!?
Reset the ECU, and see if you can feel a difference. It should honestly be negligible on a turbo car with mild mods...[/b]
Users browsing this forum: No registered users and 82 guests
