Dyno sheets (56k = go away)
Postby SpeedRacer » Sun Mar 09, 2008 9:14
<div class='quotetop'>QUOTE (MS3_Mafia @ Mar 9 2008, 03:24 AM) [url=index.php?act=findpost&pid=30969]<{POST_SNAPBACK}>[/url]</div>
Haha, I definately know that! I dedicated my Dyno runs to you today. I remembered my secret mod that might of given me a slight edge.... an fresh Oil Change on Friday! Lol[/b]
As long as you murder it out dawg its cool.
BTW I will be dynoing my stock MS3 in a few weeks and post it up here as well so you all can compare.
MS3_Mafia
Postby MS3_Mafia » Sun Mar 09, 2008 9:14
You missed some of our Highway races on the way there and back Josh... Me, Eric and Rich. Eric and I raced about 3 times.
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
and you won everytime yes?
arctic_blue83
Postby arctic_blue83 » Sun Mar 09, 2008 9:14
You guys put down some great numbers!! Especially Jack and Andrew, congrats guys! From what I understand, 2004-2006 STI's put down around 215-230whp on their dyno.
It's also plain to see what an extra 2 drivewheels do to a car, as the MS3 & MS6 both have the same motor, rated at about the same power (263hp vs 270hp), but it's obvious the extra 2 drivewheels in the AWD Speed6 soak up considerably more power than the FWD Speed3, especially considering the MS6 is rated at slightly more power stock. What did Eric and Ron have done to their Speed6's? Listing mods below graphs would be awesome :)
I also thought a while ago when Tim put down 171whp bone stock, it sounded like a bit of a freak for a stock RX-8, I guess I was right lol. Nice numbers guys, wish I could have been there.
No-Coast-Punk
Postby No-Coast-Punk » Sun Mar 09, 2008 9:14
The RX-8 numbers were interesting and kind of confirm what I've been thinking all along with these cars.
Intakes = bad. Yes they flow more CFM.... but your velocity falls off. High flow velocities are what create torque.
Both of the 8's we tested on the dyno day had intakes on them.
Tim's was bone stock.
I've been saying this for years. The OEM's are no longer stupid about performance stuff. People are closely looking at power numbers now. If an OEM can find an extra 5-10 hp from a simple re-design of their intake system... they're going to do it because it doesn't really cost them anything.
It seems that the cars that made the most power were closest to stock. I'm sure the well modded 6's will respond VERY well to tuning. But the days of simply bolting random parts on and making power are over. One needs to be a bit more methodical in their approach and single out things that the OEM's were constrained on... and tune appropriately for them.
About the only way to make power on a newish car any more to find the things that the OEM's didn't have much of a choice on due to emissions or cost considerations. Exhaust manifolds are a good place to start. A well designed tubular manifold is very expensive.... and doesn't retain heat very well. This increases the time it takes for the cat's to reach operating temp. The EPA isn't happy with that. Tuning is also a good place to start. Factory tunes are really quirky and bad to skirt around some of the inane EPA tests. A well tuned car will still pass an emissions test for registration purposes... but it might not fulfill some dumbass EPA requirement for god knows what.
Removing cats doesn't even help on an NA car. A poorly designed cat that doesn't flow well will hurt fuel economy. The OEM's have a heart attack these days when anything hurts fuel economy.
Turbo cars are a different story because exhaust volumes and temps are so much higher. Try and flow too much super hot exhaust through a cat and they'll melt down. Replacing a cat on a turbo car has slight gains (much better than on an NA car) but the biggest reason is because it allows us to run more boost now that exhaust heat isn't as much of an issue.
icon
Postby icon » Sun Mar 09, 2008 9:14
<div class='quotetop'>QUOTE (No-Coast-Punk @ Mar 9 2008, 09:08 AM) [url=index.php?act=findpost&pid=30981]<{POST_SNAPBACK}>[/url]</div>
Turbo cars are a different story because exhaust volumes and temps are so much higher. Try and flow too much super hot exhaust through a cat and they'll melt down. Replacing a cat on a turbo car has slight gains (much better than on an NA car) but the biggest reason is because it allows us to run more boost now that exhaust heat isn't as much of an issue.[/b]
i think im going to change out my intake and see if i get better numbers
2005 RX-8
MS3_Mafia
You're right Brandon about what the STI's put down... We were also told that Stock WRX's put down 155whp.
-HKS SSQV Bov
arctic_blue83
<div class='quotetop'>QUOTE (MS3_Mafia @ Mar 9 2008, 03:17 PM) [url=index.php?act=findpost&pid=31029]<{POST_SNAPBACK}>[/url]</div>
You're right Brandon about what the STI's put down... We were also told that Stock WRX's put down 155whp.[/b]
Yeah, it's a little odd though... for 2007 the STI swapped turbos, over to a VF43, whereas the previous 2004-2006 models had a VF39... I always thought the only thing different was the wastegate between the two turbos, at sea level, people seem to be making a bit more power with the VF43, but for some odd reason, up at this altitude, the VF39 powered STI's seem to make more power. No idea why, but it's been dyno proven numerous times... not that I'm complaining, as my STI was the last model year with a VF39 :D
Postby Colombia28 » Sun Mar 09, 2008 9:14
<div class='quotetop'>QUOTE (arctic_blue83 @ Mar 9 2008, 04:00 PM) [url=index.php?act=findpost&pid=31034]<{POST_SNAPBACK}>[/url]</div>
Yeah, it's a little odd though... for 2007 the STI swapped turbos, over to a VF43, whereas the previous 2004-2006 models had a VF39... I always thought the only thing different was the wastegate between the two turbos, at sea level, people seem to be making a bit more power with the VF43, but for some odd reason, up at this altitude, the VF39 powered STI's seem to make more power. No idea why, but it's been dyno proven numerous times... not that I'm complaining, as my STI was the last model year with a VF39 :D[/b]
Yeah i heard the guys at RP talking about this... really interesting information.
Rich
Postby Rich » Sun Mar 09, 2008 9:14
I just makes me sad to know AWD = 100 HP drivetrain loss
youch..
arctic_blue83
<div class='quotetop'>QUOTE (Rich @ Mar 9 2008, 06:49 PM) [url=index.php?act=findpost&pid=31059]<{POST_SNAPBACK}>[/url]</div>
I just makes me sad to know AWD = 100 HP drivetrain loss[/b]
On this dyno. On another dyno, like MAC's highly overinflated Dynojet (which uses a full/NA correction factor on all cars), Speed6's only lose about 40-50hp through drivetrain loss. Other dynos, like the the Dyno Dynamics over at Super-Rupair have put down numbers in between both of them.
Stock STI on MAC's dyno= 260-280whp.
Stock STI on RP's dyno= 215-230whp.
Stock STI on Super-Rupair's dyno= 210-245whp.
Take everything with a grain of salt. Everyone will have an argument on why their numbers are the most accurate, but honestly it doesn't matter. In my opinion, the most important factor when it comes to a dyno, is using it as a baseline, to see differences between baseline results vs modding/tuning your car. Or to compare your car to another car, in the same conditions (yes, correction factors are supposed to compensate no matter what conditions are like) on the same dyno. I wouldn't focus too much on dyno numbers. If you want to focus on anything, assuming you're a good driver, I would rather focus on trap speed in a 1/4 mile.
If you have a 3500 lbs car, and a dyno is telling you you're putting down over 300whp, but you can't seem to trap higher than 93mph, or another dyno is telling you you're only making 140whp (yes, extreme over-exaggeration lol), it wouldn't really matter what magic number either one of them are telling you right? Use it as a tool. Get your car tuned, and let the dyno show you the before and after results. That's what it's good for.
Rich
I fully agree, 1/4 mile is where the numbers are proven. I may try to do some comparisons between dyno's, both here in Colorado and in California. Really all I'm looking for is consistency. Out of the 3 Speed6's that dyno'd on Saturday, mine put down the least. Of course, mine is the least modded at this point, so it all adds up. Hopefully with a good tune and extra bolt-ons over this year, I'll get to where I want to be on the 1/4.
MS3_Mafia
You gonna go back down to Revolutions Performance to Dyno when you get your EMS Rich?
-HKS SSQV Bov
Rich
<div class='quotetop'>QUOTE (MS3_Mafia @ Mar 9 2008, 11:41 PM) [url=index.php?act=findpost&pid=31206]<{POST_SNAPBACK}>[/url]</div>
You gonna go back down to Revolutions Performance to Dyno when you get your EMS Rich?[/b]
I've got an appt. for 10:30 AM on Thursday.
Users browsing this forum: No registered users and 289 guests
