CP-E Nano Like new Used for 2 days
cyberspeed3
SOLD! Thank you
- Colombia28
cyberspeed3
cyberspeed3
wyosaint wrote:I may have to, this one I got from Cobb rubs against my IC pipe
I have a stock setup and it did not rub on anything. As far as I know, I have never heard anybody talking about the Nano rubbing on anything.
UPS Ground from Denver to Cheyenne is only one day. Ship tomorrow, you have it Wednesday.
Let me know.
deepSpeedMS3
Mel, the ms3 nano will NOT fit the ms6. Cp-e is still in production mode of the ms6 model, it is quite different. The only way it will work is if you dont use the bracket (which will rub worse than your Cobb, and it will sit there like a limp noodle), or fab up a bracket to make it work. If Im not mistaken, you have the Cp-e fmic too, it def will not work with that. The elbow off the TIP is shorter on the speed 3
Does anything work with the turbo inlet pipe and CPE fmic?? crap
sorry I'm gonna pass.
OCD wrote:Mel, the ms3 nano will NOT fit the ms6. Cp-e is still in production mode of the ms6 model, it is quite different. The only way it will work is if you dont use the bracket (which will rub worse than your Cobb, and it will sit there like a limp noodle), or fab up a bracket to make it work. If Im not mistaken, you have the Cp-e fmic too, it def will not work with that. The elbow off the TIP is shorter on the speed 3
wyosaint wrote:Does anything work with the turbo inlet pipe and CPE fmic?? crap
haha, ya.. actually, If you got the downstep coupler with your TIP, most intakes designed for the speed6 should work, however, if you got the straight 3" coupler, (which Im assuming you did, because you have the Cobb) you will either need to keep the Cobb, or wait for the Nano. Jordan says it should be ready in the next 2 weeks.
I have the stepdown piece sitting in my bucket of parts if you want it, I have no use for it.. the negatives to it is (like stock) it goes from 3", down to 2.5", and then back to 3", seems like that would be a restriction. But, you can use almost any intake.
You could also do what I did, order a 3" 45 degree silicone tube, use your Cobb maf, and make a custom intake
Powerstroke 6.0
cyberspeed3
cyberspeed3
