Threw a CEL at the track, last run.
<div class='quotetop'>QUOTE (SpeedRacer @ May 23 2008, 07:38 AM) [url=index.php?act=findpost&pid=47752]<{POST_SNAPBACK}>[/url]</div>
WTF?
Awww CAREBEARS SHARE![/b]
WTF?
EvoXGuy
<div class='quotetop'>QUOTE (Rich @ May 23 2008, 09:28 AM) [url=index.php?act=findpost&pid=47781]<{POST_SNAPBACK}>[/url]</div>
Souds like it well i hope that CP-E will stand behind it and take care of it. They should they have been good to us so far.
Sure did. Not sure but I'd say it's possibly a PCB failure within the harness.[/b]
firestoned
haha that is true.
Have you thrown in some lower octane gas to offset the high octane you put in for the run?
I've seen this on my Saabs.
The MAF Sensor may be dirty or faulty. The use of oiled air filters may cause the MAF to become dirty.
There might be a vacuum leak downstream from the MAF sensor. Try taking it off and cleaning it with electronics cleaner or brake cleaner (spray) Make sure you are careful not to damage the MAF and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses.
You may want to check for a dirty fuel filter and proper fuel pressure
See my previous post. You will usually get the misfire code with a vacuum leak.
<div class='quotetop'>QUOTE (Greek8 @ May 21 2008, 10:33 PM) [url=index.php?act=findpost&pid=47502]<{POST_SNAPBACK}>[/url]</div>
I got a CEL to. Random Missfire in cylinder 1.Bad coils or plugs. Mebe motor? Who knows?[/b]
- Rich
<div class='quotetop'>QUOTE (AIM WO4 @ May 23 2008, 02:35 PM) [url=index.php?act=findpost&pid=47850]<{POST_SNAPBACK}>[/url]</div>
Well since I've reset the ECU, the CEL is gone. Since I just installed a fresh filter, I'll be sure to examine the MAF. Thanks for the advice
You may want to check for a dirty fuel filter and proper fuel pressure[/b]
firestoned
<div class='quotetop'>QUOTE (EvoXGuy @ May 23 2008, 09:16 AM) [url=index.php?act=findpost&pid=47775]<{POST_SNAPBACK}>[/url]</div>
The battery only needs to be unhooked the first time you install the harness and standback.
Rich, thats great news you'll be up and running faster soon.. sucks that youve had these 2 issues with the standback, knock on wood, everything is fine so far here...
Did you unplug the battery every time you pluged and unpluged the standback?[/b]
EvoXGuy
<div class='quotetop'>QUOTE (firestoned @ Jun 9 2008, 01:16 PM) [url=index.php?act=findpost&pid=51016]<{POST_SNAPBACK}>[/url]</div>
And every time you unplug the standback to put the bypass plug on. Good to here that they took care of you I am starting to like CP-E more and more.
Rich, thats great news you'll be up and running faster soon.. sucks that youve had these 2 issues with the standback, knock on wood, everything is fine so far here...[/b]
