20251212_174255 by Eric Jausel, on FlickrBuild thread
Re: Build thread
OneGauge sent me another update today and everything is working now. The temps are still slightly slow, but they're much better than they were. They look like they're updating every few seconds now at least. AFR is still a bit slow. They're looking into that more, but so far stumped as to what the issue could be because they said Haltech comms are always fast. Full tank reads a bit high still but I honestly don't care at this point lol, at least it reads zero at empty. EGTs and the ambient and intake temps were a few degrees off from what the ECU read when the key was to accessory before starting it, but I'm not too worried about that especially since EGTs will be so high anyway, a few degrees doesn't mean much at that point. My fuel pressure is reading a bit low because I guess the graph I used for the sensor I'm using wasn't perfectly accurate, but the gauge matches the ECU. I put a mechanical gauge directly off the FPR where the pressure sensor is mounted and the gauge reads 43 while the ECU says 36ish. Pretty much all the gauges (other than the temps I mentioned before) read spot on or within a number of what the ECU says. The odometer is constantly running codes currently, OneGauge is using that info to troubleshoot the slow gauges. Of course after all of this is sorted, I still need to finish the gauge hood with filler and paint. I didn't see the point in doing that while I was still removing the dash piece on a regular basis. My interior has been partially disassembled all summer because of this.
20251212_174255 by Eric Jausel, on Flickr- speedjunkie
Re: Build thread
Well, it turns out my boost issue is not fixed. I got the same 'trigger reference error' CEL again tonight, and on the second pull it even killed the engine again.
Another thing I forgot to mention about the fuel temp reading. I was talking to Brett and he said it could be that the flex fuel sensor failed and the readings are backwards now, indicated by the temp starting at pegged out on the top end and dropping as I drive.
Re: Build thread
I got another updated hex file a few days ago and almost all the gauges update much quicker, although the fuel and oil pressure gauges are still somewhat slow. And the flex fuel sensor isn't bad, it just had the wrong calibration, and Ryan Heinrich got into it tonight and fixed that and set up my knock sensor.
I think the problem with the fuel level sensor might be due to the wire itself. I soldered the end of the wire that connects into the OneGauge hub and some of the strands are broken just before the solder, so I'm wondering if they're causing the resistance to change and therefore throw off the fuel level reading.
Re: Build thread
I bought a new Haltech flying lead harness from Joe, but I've discovered that it won't work for me because it's missing the second Knock input wires, so it kinda defeats the purpose lol. I'm not sure if I'll have to buy the harness from Haltech or what. The one I got from Joe is a 1500 premium harness, and they're listed on Haltech's website as the same as a 2500 or 2500T premium harness, so I figured it would be fine. I don't need the premium harness since it comes with a relay box I'm not going to use, but it was cheaper than buying the basic harness from Haltech.
Joe had also mentioned that the fuel level wire needs to be filtered in the software on the OneGauge hub, so I'm going to see if they can try that first and fix my fuel level issues. But either way, the full ohms need to be changed again. It seems that the ohms at the full end of the readings are a bit wonky, they get unstable if you hold the float all the way up so I'm shooting for an ohms reading just before the top, and hopefully between that and the filter it will be fixed. I had checked the fuel level wire and it didn't have broken strands like I thought, I must have been thinking of a different wire.
I drove the car to Denver last week to pick up the harness and do a full test of the gauges, and I noticed that the ebrake light flickers on and off somewhat in a rhythmic pattern while cruise control is engaged and that light is on. Weird, and worrisome. I really don't want to fry another board.
Re: Build thread
I got an updated file from OneGauge today and the fuel level was a bit closer, at 90 full on the gauge, and the ohms readings were all over the place depending on where I measured and different things with the multimeter. They said the fuel level gauge is already filtered.
I've been thinking about making the new harness expandable, adding connectors in different places so I can add sensors or whatever else later if I need or want. Although that would add several connectors that I may not ever need, so I can't decide whether I want to do it.
A few days ago I found some LEDs that I'd bought to put into the dash buttons and forgotten about, and I had some burnt bulbs in the cruise control buttons and headlight motor switch, so I replaced those. The headlight switch is a bit dim so i might try to open it and add some foil tape to reflect the light some. It's not a huge deal, but it's the little things lol.
I found an extra water pump manifold and filler neck in my parts pile so I started modifying those to swap on, cutting off the bracket for the air pump and pulling the turbo coolant nipples to tap the holes for AN fittings. I also ground down the ridges where they were cast together. Now I just need to figure out what kind of coating they're going to get.
I was thinking about changing my FPR to a Radium that mounts directly to the rail, but it only has the one inlet, so it won't work for me. That would have been great though since it would have allowed me to raise the engine again with normal engine mounts and that would keep the oil pan from hitting the ground.
Re: Build thread
One of Chris B's friends that came through town several months ago posted about finding that the early 2000s Protoge wiper motor fits the FD, although it uses a different connector but the same terminals so it can just be repinned. I love having spare parts, so I picked one up from the local UPAP for about $20. He had also mentioned how fast it was, but later said he didn't notice if it was faster but he just needed a motor. The original wiper is SO slow, especially if the windshield is not sufficiently wet. I checked last night and it's only getting 8-9v, which is a common problem on the FD with motors since they didn't use many relays on the car. So I decided to remedy that the same way I did the windows, adding relays. I ordered a 451m dual relay like I used on the windows, but realized last night that I really need 3 relays instead of 2, since there is intermittent as well as slow and fast. I was initially planning to mount them in the wheel well next to the wiper motor and make connectors and harnesses for each wiper motor, but now I've decided to put them right at the connector on the steering column instead.
I've been talking to Brett about the fuel pump system and how I want to use the stock wiring so it can run at 9v most of the time and then bump up to 12v when needed, and I think I discovered why it wasn't working in the past. I think I have to run two wires from the ECU, one to trigger the 9v system, and the other to trigger the 12v system. But I need to do more digging into that. I'm going to do that with the new harness if I can though. Although I do like having the priming switch at the back of the car by the pump hanger rather than having to put the fuse in the diagnostic box. I might add another pump back in the tank eventually and stage the extra pump so it comes on under heavy boost, but I don't think it's really needed unless I'll be running ethanol. I picked up my spare fuel tank from Jason so I can start modifying it with an internal surge tank like I've been planning to do for years. I'll somewhat copy Adam Griffith's tank (https://www.rx7club.com/build-threads-2 ... ntent=post), although he told me he had a lot of issues getting good welds on it. I'm planning on making it a little different with 3 or 4 different sections of the tank, where the fuel will be trapped closer to the pumps in each section (at least from the passenger side). Although to do that I'd have to cut the tank in half where it's joined rather than removing just the highest portion like Adam did.
I'm also planning to switch to a different fuel level sender if I need to. The stock one is just too unreliable to give an accurate reading. First I'm going to try running it to the ECU first, then through CAN to the display. But if it's still unreliable, I plan to switch to one of these https://inverterservicecenter.com/10-1- ... s-jks02193, or something like it. The float is made of NBR, which is decent with ethanol in small amounts, like regular unleaded with E10, or E85 if used for a short time, but sitting in it will eat away the float over time I think. I'm waiting to hear back from KUS. I'd really like to find one that's suitable for ethanol. But either way, I want to get this fuel level issue sorted ASAP.
Re: Build thread
I've been buying all the parts needed to build the harness. I started digging through old info to see why I can't use the wiring from the EGI relay to power the ECU, and I ran the wire to it again, and again the car wouldn't turn off when I removed the key. After some troubleshooting, I discovered the EGI was powered on both side of the relay and narrowed it down to the ECU relay box. Joe suggested a new way to wire it and I did that today, and it fixed the issue. Or at least I hope it has. I didn't think I was using the ECU relay anymore so I left it out and the car wouldn't start. I put the relay back in and it started, but then I noticed the fans were on after I turned off the car. I pulled the ACC relay and they went off, but I believe it was just some crossed wires from my crazy wiring used for testing. So I think it's all good now.
I bought a 1/8NPT tee fitting, a schrader valve, and a gauge to calibrate my pressure sensors. My fuel pressure reads around 37psi when it's supposed to be 43.5, so I figured it wasn't calibrated. I had tested the pressure within the last couple years with the old gauge from my FPR, so I knew the pressure was still good. But the sensor seems to be pretty much perfectly calibrated because the ECU reads what the gauge does all the way through the range.
I have all the connectors for doing the wiper motor relays so I think I'll be doing that soon as well as building the new harness. And instead of running a new wire from the fuel level sender to the cluster, I think I'm going to go ahead and run it to the ECU. It seems others have done this and don't have issues with it being incorrect. I already bought a few different resistors to use on this.
Re: Build thread
I replaced the bearings in the Pineapple Racing idler pulley today, and I'm a little worried because they're loose inside the pulley. You can almost press them in by hand. And the old bearings were like that too, they pressed out super easy. I fear the pulley itself is too worn, and I'm not sure I could get another one since the owner died.
I tried lubing the rear lower control arms too, the bushings in subframe end, but I forgot they're OEM bushings so I don't think they'd need to be lubed. Furthermore, I couldn't get the arm out of the hub, and if I pushed the hub outward, it put too much stress on the brake line, so I ditched that idea. I was thinking maybe the noise is coming from the diff bushings, but it only makes noise when going over a bump or pothole, so it almost has to be the LCA. Maybe the rubber is making noise.
I have the harness all laid out and I finally know how to wire the relay box. I rewired it a couple weeks ago to see if I could find a better place to run the 12v switched power to the ECU and it ended up staying on again when I removed the key. I discovered that the relay box still wasn't wired correctly from three years ago and I think the coils and/or injectors were getting power constantly. I have almost all the supplies needed, but I keep finding that I need more. Plus I'm a little nervous again about building the harness lol.
Re: Build thread
I've been building the harness over the last week. I have all the wires added, although I might have to change a couple of the ignition coil sensor ground wires because I messed up and somehow grabbed a shorter wire and don't have one long enough for the coil at the front of the engine, although I did mark the wires longer than needed and it might actually be OK.
I also had some issues a few days ago with the very first crimp on the sensor ground wire, and ended up cutting the wire where I almost didn't have enough left to fix it. Needless to say I lost my mind lol. And I decided to never again use those crimpers for that task. I was able to fix it, but it's not pretty. The good thing is it isn't visible so it doesn't really matter, but it still bugs me to no end.
I need to order a few more parts for the harness, but all I have left is trimming the wires to length, adding the rest of the heat shrink, adding the heat shrink labels, and terminating the ends with connectors. It sounds like a lot, but it's actually more enjoyable the closer you get to completion.
I'm going to try using the stock fuel pump wiring, but I have provisions if that doesn't work. I'm running a harness all the way to the back where I have new, smaller relays I'm going to use (the same ones I'm using for the wiper motor project). It will have wiring for three pumps, and the wiring for running the fuel level to the ECU so I can see if that fixes the last issue I'm having with the digital display. It will also allow me to change the fuel level settings myself instead of relying on One Gauge. I have to run the signal wire, a 5v wire, and sensor ground, and use a 220 or 240 ohm resistor between the 5v and signal wire (I'll do that within about a foot of the ECU), and I'm planning on using a different connector at the battery so I can add in the wiring from the battery for the relays. Then I'll have to set up all the fuel level stuff in NSP, but hopefully that won't be too bad. The upside is this will free up an opening in the One Gauge hub for the seatbelt wire, although I really don't need it and I'm not even sure it's working lol. I checked resistance on the stock fuel pump resistor and it read 0.9 ohms, and it's supposed to be between 0.5 and 0.7 IIRC, but others have gotten the same reading, so I'm wondering if it's just due to the leads on the multimeter or something.
I also added a connector near the ECU that has sensor ground, chassis ground, 12v switched from a relay, and 5v, so the harness is expandable without having to cut into it. I thought about adding a couple connectors in the engine bay for this with a few different terminals for each, but I really only need one each because the expanded harness can expand on each of these wires if needed. All I might need is a place to tap in to each of these. I thought about adding one for battery ground, but I'm using a larger gauge wire for that, and I didn't even really need to add one for chassis ground since I can just run that separate. I had also thought about making the coil and injector wiring in subharnesses so if I wanted to add more of those I can expand them as well, but I can just cut the harness and add it if I need to, which I probably won't anyway. I'm pretty happy with how the car is built now.
I also realized that the relay box was wired really incorrectly compared to the Haltech relay box, so I'm going to completely rewire it starting from scratch. And I'm going to get power for water injection from that box as well instead of running it separately from the battery.
I was talking to Haltech about the CAN connector I added to the last one and am adding to this one, trying to determine exactly how it needed to be wired, because they way I wired it last time was different from the way they wire the one they include on the flying lead harness. Theirs is supplied 12v switched from the ECU relay, and run to sensor ground. Mine was 12v switched from the ACC relay (basically the same thing, no biggie there) but it was run to chassis ground. I started wondering if this was why I was having issues with the OBDLink OBDII adapter connecting signal and battery ground when connected. The Haltech person kept repeating that I needed to have them wired to 12v switched and battery ground, like they do on the Nexus harnesses now, so there's no chance of the two ground types connecting before the ECU can do it. I kept asking about the issues I had had, and why Haltech wired theirs to sensor ground. He finally said I needed to rewire the one they included. Good to know, and it only took four days of emailing lol. I did make it reversible just in case.
There are a few other tasks I need to complete. For troubleshooting the WOT boost issue, other than making the new harness, I want to swap the TPS, check the harness that runs under the passenger fender to make sure it's not grounding to the chassis or something, and check the spark plug wires for openings (that's something Ryan Heinrich suggested). But Joe told me the issue is visible on the logs at all times, not just WOT. I'm running the CAS wiring as far away from the coils as I can, but it will still be right under the alternator.
I also need to plug the coolant sensor port on the engine since it won't be used anymore, and it'll make the oil pressure sensor much more accessible if I need to change it. But I want to do this at the same time I'm changing the water pump manifold and filler neck. Xavier welded all the holes closed in the filler neck, including the ones that had set screw plugs from the factory. It looks so clean now. Now I just need to decide which powdercoat I'm going to do. I'm thinking about doing a wrinkle coat this time. I've always loved it. But I'm trying to decide on black or silver. I'm looking for a really light silver so it looks more stock, but Prismatic doesn't have one that matches really well. I'm wondering about black on the engine parts still, and then silver on the IC piping, manifolds, TB, etc. Or just do silver on all of it. I'm kinda over the blacked out thing. Lighter colors looks so clean. Having cut off the air pump bracket from the water pump manifold, and opens a lot of space for mounting the FPR right on the end of the secondary rail, and if I did that I could raise the engine again and I wouldn't need to change my oil pan to a shorter one, and I'd add a bung for the oil temp sender to get a more accurate reading. And if I mount the FPR on the rail, I'll try to find another JDM UIM and cut off the mounts I'm currently using for the FPR so it'll make it even cleaner, AND I wouldn't undo the polish work I had done on this one. Seems like such a waste of money lol.
And, probably most importantly out of all this, I need to check the driver's rear brake line to make sure I didn't damage it when trying to lube the rear LCA, so I don't die lol. I realized that I put much more pressure on the hub than I initially thought, and probably damaged the line.
Re: Build thread
The heat shrink I need won't be here until Monday, so I can't finish the harness until then. However, now I need to do some other things before finishing the harness and running the car anyway. I found a new way to route the CAS cable, and ideally I need to swap the water pump manifold to do it. I could probably get away with keeping all that on the car as it is, but the connector would be coming up into a water temp sensor that I added several years ago into the back of the housing right behind the thermostat, and the new manifold won't have that. So I need to decide which powdercoat color I want and get them done so I can install everything.
I wired the relays for the wiper motor project today, but realized I bought 12 way connectors and the way I'm wiring it will only need 4 way connectors at most. I was debating on using power and ground from the stock wiring or running power to the 12V switched fuse strip and chassis ground. I decided to try to keep it all within the stock wiring, especially considering there will only be one relay engaged at any given time (if at all), so there isn't a reason to power it directly from the battery. That's assuming it's actually getting 12V at that point in the wiring, I should probably check that lol. But it's only going through the ignition switch and the fuse box at that point.
While I was messing with the relays, I discovered that the bearing I had pressed into the clutch pedal was pushing out one side, so I removed the pedal, pressed it back in, and dimpled extra hard around the hole with a center punch. I may have gone too far at this point because the center of the bearing doesn't move as freely as it did before lol.
I also got the wires for the fuel pump/level subharness, but I need the 1/4" heat shrink for that as well. And I uploaded a new hex file from OneGauge to the hub to get fuel level from the ECU and run the seatbelt wire to the hub, and added the seatbelt indicator back to the display.
Over the last few days I checked the spark plug wires for openings (they looked good), removed the oil temp sensor on the filter pedestal, and cleaned the CAS connector. Devon (one of the local guys) started having similar issues with his car where he gets similar codes on the CEL, but his drops out at any given time. He cleaned out his CAS connector and it seemed to fix the issue for a short time, so I thought that might help, but his problems came back. Either way, mine was pretty nasty.
Re: Build thread
So much has happened over the last couple weeks I can't even remember everything.
I finished the harness, and upon installing it, immediately broke every single coil pack connector, two of them when connecting and two when disconnecting. The locking tabs broke, specifically. I contacted MilSpecWiring and had replacements sent, and I bought some extras from Corsa Technic as well. I installed the new ones last night and they went on with no issues, not yet anyway.
I've been working on the fuel pump harness still and got the new relays wired and mounted at the rear of the car. All I need to do now is rewire inside the tank. I'm going to try to use some Radium posts for the fuel pumps since the wire is so big, and they'll be here tomorrow, but I'm not sure they'll work with the CJ hanger. And speaking of fuel pumps and such, I think I'm going to use Billy Johnson's method of solving fuel surge. He's using a Hydramat with a lift pump and pushing the fuel into the stock plastic baffle with a Garage Alpha surge tank cover, which is a copy of the old Hyperion cover. I might have to use the FEED collector box I already have installed, or maybe I'll make another tank to put inside the plastic baffle, if I can get it to fit through the opening. https://motoiq.com/project-fd-rx7-resto ... tarvation/. I'm also considering only activating the lift pump once fuel level reaches a certain point. No reason having it going when the tank is full. Here's the connector in the rear bin where the battery is mounted, with the resistor in line for the fuel level, and before adding the 10ga wire to the pump relays.
20260303_213611 (1) by Eric Jausel, on Flickr
I got the water pump manifold and things powder coated Medium Grey Wrinkle from Prismatic and they look fantastic! I also swapped on the billet filler neck piece from Banzai, as seen in one of the photos.
20260317_183816 by Eric Jausel, on Flickr
20260317_214245 by Eric Jausel, on Flickr
I pressurized the brake lines by pressing the pedal a couple times and it didn't leak, but I'm still going to take it to a brake shop to have the lines pressurized. While I was doing that, I discovered the squeaking source, the upper control arm bushings, so I pulled those off to lube them. When I got to the passenger side, I noticed the same bolt that seized in the UCA last time (about 10 years ago) was trying to seize again. It came out easily, probably only because I used dielectric grease on the inner part of the bolt last time. It had a bunch of rusty dust on it and the bolt has weird wear patterns on it. I reinstalled with extra dielectric and more anti-seize on the threads.
I swapped the OMP block off plate with a nicer one that has better fitment. It came with plugs for the OMP injector holes too but I already have those plugged with set screws and didn't feel like swapping them right now.
20260310_183914 by Eric Jausel, on Flickr
I figured since I cut off the excess from the water pump manifold, I might be able to fit my FPR on the end of the secondary fuel rail now so I started to test fit it. I'll get the Radium fittings tomorrow to see if it will actually work. Then I just need to order the stainless tube and some fittings. I need the tube for the turbo coolant lines too, and I was thinking about making those now since I have the coolant drained, but I want to get the car back on the road. And if I can move the FPR to the rail, I'm going to cut off the mount brackets for where it's mounted now and open up the underside of the UIM more. I bought another JDM UIM for this purpose, on 7club, so I don't wreck the one I have, partly because I want it usable if I want to go back to the old way, and partly because I can't bring myself to ruin the polished surface, because I'll be powder coating all the intake piping, manifolds and such as well.
20260310_183935 by Eric Jausel, on Flickr
I picked up a heat shrink boot from Brad for the turbo speed sensor, but I'm not sure how to get it on without depinning the connectors, which seems to be impossible.
I bought a new crank angle sensor from FFE but I haven't gotten it ready to install, I'll try the old one first. I also left some extra shielding at the connector, we'll see if it screws me over lol. I folded back the extra green wire and disconnected it from the ECU connector as well.
20260303_213611 (1) by Eric Jausel, on FlickrI got the water pump manifold and things powder coated Medium Grey Wrinkle from Prismatic and they look fantastic! I also swapped on the billet filler neck piece from Banzai, as seen in one of the photos.
20260317_214245 by Eric Jausel, on FlickrI pressurized the brake lines by pressing the pedal a couple times and it didn't leak, but I'm still going to take it to a brake shop to have the lines pressurized. While I was doing that, I discovered the squeaking source, the upper control arm bushings, so I pulled those off to lube them. When I got to the passenger side, I noticed the same bolt that seized in the UCA last time (about 10 years ago) was trying to seize again. It came out easily, probably only because I used dielectric grease on the inner part of the bolt last time. It had a bunch of rusty dust on it and the bolt has weird wear patterns on it. I reinstalled with extra dielectric and more anti-seize on the threads.
20260310_183914 by Eric Jausel, on FlickrI figured since I cut off the excess from the water pump manifold, I might be able to fit my FPR on the end of the secondary fuel rail now so I started to test fit it. I'll get the Radium fittings tomorrow to see if it will actually work. Then I just need to order the stainless tube and some fittings. I need the tube for the turbo coolant lines too, and I was thinking about making those now since I have the coolant drained, but I want to get the car back on the road. And if I can move the FPR to the rail, I'm going to cut off the mount brackets for where it's mounted now and open up the underside of the UIM more. I bought another JDM UIM for this purpose, on 7club, so I don't wreck the one I have, partly because I want it usable if I want to go back to the old way, and partly because I can't bring myself to ruin the polished surface, because I'll be powder coating all the intake piping, manifolds and such as well.
20260310_183935 by Eric Jausel, on FlickrI picked up a heat shrink boot from Brad for the turbo speed sensor, but I'm not sure how to get it on without depinning the connectors, which seems to be impossible.
Re: Build thread
I worked for almost 12 hours yesterday trying to finish the car so I could attend the meet, but no luck. I almost finished it tonight though. I assembled the most of the dash, finished the fuel pump harness, and picked up more coolant and power steering fluid. I pumped almost all the fuel out of the tank so I could complete the inside portion of the fuel pump/fuel level wiring. I changed the connectors inside to some rated for fuel and replaced the bulkhead connector inside the tank. I bought some bulkhead bolts from Radium because I had such a hard time getting the 10ga wires into the connector, but they weren't even close to long enough to work on my CJM hanger. I would have had maybe a couple threads to add the nut to hold them in, so there definitely wouldn't have been any threads left to attach the wires inside. I was thinking about maybe modifying the stock hanger so I could use the bolts in order to run three pumps, but then I'd be back to one pump anyway unless I figured out a way to fit an extra couple pumps on there. If I stick with the CJM hanger I'll have to run the lift pump on the same circuit as the main pump if I want to stage the second pump. I ran three relays for the fuel pumps so I could run two pumps and a lift pumps separately, or three pumps with the lift pump run off the main pump wiring, and I ran all the three relay power wires to the tank, then realized my predicament, so I have an unused wire from a relay going to the hanger, and of course when I was finishing the wiring tonight, I connected the wrong wire. Good thing I can just change it in the NSP software.
I don't think I'll be able to move the FPR to the end of the rail, there really doesn't seem to be enough room for it. The only way is if I can find a smaller FPR that still has two inlets, which I haven't found yet.
All I need to do now is run the car to bleed the coolant and bleed the power steering system.
Re: Build thread
I started the car and bled the coolant and power steering tonight, but I discovered a couple problems.
I think I have an issue with the front harness that I installed three years ago, or the junction box by the driver's left foot. The EGI relay is getting power as soon as I connect the battery, and therefore powering the ECU immediately, without even turning the key to accessory. So there must be a short somewhere. I started thinking maybe it was in my relay box wiring again, but I've tried a few things with no luck. So I knew right away that if I started the car, it wouldn't turn off. I swapped the pink power wire for the ECU back to the one I connected to the ignition switch to temporarily fix that issue until I properly fix it. What's wild is that the relay box still got power even when I forgot to reconnect the stock X-05 connector, which also has the first fan wire, so my fans didn't come on and I reached 201F and the coolant started boiling over the funnel. OOPS! I kicked on the AC real quick so the fans would come on full blast and it cooled it down quick, then I connected X-05 and verified the fans came on.
The other issue is my wiper relay modification doesn't work haha. The intermittent setting works, and they are fast, but it's not intermittent, it's like regular, and when I try the regular setting the fuse usually blows but didn't one time, and if I try the fast speed the fuse blows immediately every time. So I'm giving up on that project lol. Such a shame, because they really are faster.
And I forgot to mention that yesterday I also modified the headlight motor switch a bit. I had noticed that some lights were out in that switch and one of the cruise control buttons, and I've never liked the amber color so I swapped those and the ones on the HVAC panel with white LED lights, but I noticed the headlight motor switch was kinda dim. I opened it and discovered the pathway for the light was a bit winding and it isn't a direct shot from the light, so I added some foil tape and it pretty much perfectly matches the brightness of the cruise control switches now.
Re: Build thread
I got the car back to driving last week and I've been driving it most days this week. I do have a slight coolant seepage where the water pump mates to the manifold, and also where the filler neck mounts to the manifold. I reused the water pump gasket because it was still good from when I replaced it a few years ago, and I used a new gasket from the manifold to block. I reused the thermostat and seal as well, but that one really shouldn't be leaking at all. I dropped off my parts that I was just using to Nick so he can strip the old powder from them and I'm going to modify at least the manifold so I can get that one coated as well and I'll use those instead since I know they won't leak, and I'm getting new gaskets as well.
I broke the phone mount because I was sliding the passenger seat forward and didn't realize it was in the way, so I replaced that with a magnetic mount and since it has a light on it that stays on, I ran it to the power strip that connects to the CB so it doesn't drain the battery. I did leave the key on Tuesday night because I was pulling a log from the ECU and forgot to key off and that drained the battery enough to not be able to start it Wednesday morning, but it's fully charged again now and I drove it today again.
And my Autovox dash cam is in a constant boot loop when it gets power, so I have to contact the company about that one. The fuse for it in the power strip by the battery had blown, so I replaced that and now it just loops. I tried removing both fuses it needs, nothing worked so far.
My wiring issue was from the ECU, not in the front harness. When I'd disconnect the ECU or the connector to X-05, the problem went away. I actually found another issue that wouldn't cause the car to not run, but also wasn't good. I had A26 going onto to X-05 (and disconnecting that fixed my issue), and that wire is supposed to go to the same relay that is feeding power to the injectors. If they are wired to different relays, there can be an issue with fueling, so I disconnected it from X-05 and ran it to the output (87) of the injector relay. My relays are still chirping when I connect the battery, haven't figured that one out yet. The only way to fix that is to remove the relays completely, and I can't do that. It doesn't seem to have any other wiring issues that I can tell though. So until I hear what could be causing that, I'm gonna rock it as is.
Re: Build thread
I think the coolant seepage is fixed. I bought some gaskets and a new thermostat and seal, but Napa had thermostat seals also so I picked up one from them, and it occurred to me that it was probably just that and dripping down onto the water pump making it look like it was leaking also. I pumped out enough coolant from the filler neck and swapped the seal on the thermostat, drove it tonight and I don't see any coolant.
While I was doing that I also put some Loctite 638 retaining compound on the bearings for the Pineapple Racing water pump idler pulley. I'm not sure of the reason, but the bearings had gotten super loose inside the pulley (likely because of Nickel plating wearing off after swapping the bearings a few times). They were so loose that I pushed them out and back in by hand. I let that cure for almost 24 hours before tightening the belts tonight for a drive. And I also swapped the CAS for the new one I bought a couple months ago since I still have the trigger issue, but it doesn't seem that fixed the problem either. I'm wondering if I need to check timing with the gun again. After that, it's time to try a new tune.
For several years now it has seemed like the fuel pressure was reading low. I just remembered recently that when you set the FPR, you remove the vacuum line first. Once you reconnect the vacuum line, the pressure will be lower until you start building boost, as long as it's a 1:1 rising rate FPR. So I disconnected the vacuum line and it was reading 40psi, but when I have the car off and I turn on the fuel pump to prime, my gauge reads 42psi. Close enough. Speaking of fuel pressure, I'm looking into why NSP doesn't update fuel and oil pressure readings more than ever couple seconds. Seems a bit ridiculous.
I haven't heard anything back from Autovox about the dash camera yet, so I might have to just look for a better one. Or see if there is some way to reset it or fix it somehow.
I don't remember if I mentioned it, but I checked for continuity between signal and battery ground with the OBDLink connected and there is no continuity! However, I've discovered that the OBDII cable isn't even getting powered from the CAN cable anymore. The OBDLink dongle flashes different indicator lights when it's connected (and possibly when it isn't), so I thought something was wrong with it. But I connected the ELM27 bluetooth dongle tonight and got nothing on that either. The OBDII cable is connected to the same CAN connector, but I had rewired that one with battery ground and I think 12V from the ACC relay, so I'm not sure why it's not working now.
I think the fuel level gauge is working OK now, but it's still questionable at times. I had put in values from another member on 7club instead of checking my own sender, and after driving the car for 5 days it was reading 60%, which I questioned because it used to need a refuel after 5 days of just driving to work and back. I opened the tank and there was barely any fuel in it, I don't even know how I made it home lol. It looked like there was maybe 1/2 to 3/4" of fuel in the tank. Apparently the FEED collector box does work OK lol.
