'92 Miata: Budget Project Car
Postby RX-7 Chris » Tue Jul 15, 2014 9:14
I couldn't remember but did you get SS hoses with that setup?
Postby Huzer » Tue Jul 15, 2014 9:14
RX-7 Chris wrote:I couldn't remember but did you get SS hoses with that setup?
Yep, SS hoses all around. No leaks at the caliper or at the hardline connections. The brakes were mushy before, I figured I didn't do a good job bleeding the first time around when I did pads/rotors. This time, I know I had no bubbles in the lines. I made sure to hit both top bleed screws on the fronts.
Postby Huzer » Sat Jul 26, 2014 9:14
Brake job, part 2. I'll hopefully be done sometime tomorrow, as I'm not in too much of a hurry. Got it up on stands today, but have some plans for later. I'll probably get everything wrapped up tomorrow.
Hmm, I guess I'll need assistance on the brakes. I had my wife help me bleed and no difference. Change the master, bench bled, now it's worse. I guess my level of brake knowledge is replacing pads and rotors. Odd, I've changed lines on the MG, the RX8, and didn't have this much difficulty bleeding and getting the brakes back to normal. To take it to a shop at this point, I'd have to tow it, as the parking brake is the only brake that feels solid.
Justin
Postby Justin » Sat Jul 26, 2014 9:14
Keep bleeding. It took me a couple of quarts of fluid to get the lines fully bled the last time I did my Bronco.
Thats's the current plan. I'll do another flush/bleed tomorrow and go from there. I know it's air and not leaks.
Postby Huzer » Sun Jul 27, 2014 9:14
Success. My wife got another leg work out pumping the brakes. I had significant air in the RR, and then I had to restart when I sucked the MC dry. Argh. Quick alley test drive shows a significant difference and I'll take it for a test drive in a little bit to see how they are at speed. Definitely a solid pedal now. Wee.
Also, my MityVac is broken. I thought I had spilled brake fluid on the handle, then noticed it just pouring out of the handle and it wouldn't hold vacuum.
Postby Shadowden » Sun Jul 27, 2014 9:14
Invert a large fluid bottle in your reservoir. Shouldn't run out of fluid if you essentially make the reservoir about 6x larger.
Way to get it done!
Test drive successful as well. Have to add that my passenger side rear clunk was a loose battery.
Loose small battery or loose car battery.
Congrats on getting it figured out and the mas powerful brakes installed. Did you have to bed them?
Car battery. It was secure enough to not flop around, but not tight enough that it didn't have some movement.
I did bed them. Some hard stops from 40 and 60mph. Nice solid pedal, good bite, stops quickly.
Postby RX-7 Chris » Mon Jul 28, 2014 9:14
nice!!!!!
Postby Huzer » Mon Jul 28, 2014 9:14
Thanks. I also got my son involved. I let him tighten the lugs while the car was still in the air. He really got a kick out of using the ratchet.
I can't wait until I can do that. How old is he now?
Postby erod550 » Mon Jul 28, 2014 9:14
Nice job, sir. I chickened out when my master cylinder was leaking and needed replaced. I took it in to have that done. I have replaced calipers and done just about everything else brake related but that one worried me a bit.
Return to “Piston Vehicle”
