jbr egr delete
pyrrhus17
jbr egr delete
Postby pyrrhus17 » Mon May 13, 2013 9:14
Does anybody here have this mod ? can you tell me what it does ? how do you like it . Thanks
Mortose
Postby Mortose » Mon May 13, 2013 9:14
I had it for a while. No real issues in the negative. I've since switched to the ssp egr delete.
What it does is prevent the exhaust gasses from being routed back to the intake mani, therefore keeping your valves clean.
You gas mileage will go down, an you may see a little more knock due to higher cylinder temps, but that's really it.
pyrrhus17
Postby pyrrhus17 » Tue May 14, 2013 9:14
Thanks Mortose do you like the ssp egr delete better ?
Mortose
Postby Mortose » Tue May 14, 2013 9:14
well, its kinda mandatory for BT, with the new intake. It would be a TIGHT fit without it.
