Thanks all.
I'm going to pick up an interstate battery over lunch today so we can get the car started hopefully tonight.
My New Toy
It really is good to see things moving along now. It's looking good. I'm sure you're anxious to be done, too.
I'm very anxious for the car to be done.
I installed the strut rod/sway mounts. I still need to pull the control arms and replace those bushings. Once I do that I can finish the suspension.
I am. The strut rod mounts, etc. were sandblasted, primed, and painted with Eastwood Extreme Chassis Black.
http://www.eastwood.com/ew-extreme-chassis-black-primer-aerosol-14-oz.html
http://www.eastwood.com/ew-extreme-chassis-black-satin-aerosol-14-oz.html
Here is the front end completely installed:
I made some mounts for the exhaust heat shield. The old mounts rusted off. They still need to be welded but that is it. I'll get a pic when everything is installed.
Pipe:
Shield:
Mounts:
Pipe:
Shield:
Mounts:
On friday, I installed the shifter, primed the oil, and started the car up. The car has no leaks. I need to still get the car to operating temp and get the bubbles out of the coolant system. The clutch and brakes need to be bled still. After that, all that is left is body work and paint stuff.
I will probably ask you for it once the car is done. No real need for it right now, lol.
The brakes and clutch are bled now. The A/C is charged.
The rust around the windshield is fixed finally.
I took this pic before he painted the beige. He had two rust holes to fix and it was basically bubbling rust all the way around the frame. He painted two coats of primer and two coats of beige. There is no way this will rust again.
The windshield will go in today.
Windshield is in.
Users browsing this forum: No registered users and 209 guests
