Thanks man
Not too horrible for a 21 year old Mazda.
UPDATE:
I got new Yokohama ADVAN Neova AD08 tires (205/50/15's) on the car today. I also stopped by Ace hardware and picked up a couple bolts that were missing for the mounting bracket for the P/S. I'm missing a few more bolts, but can't clearly see where the "cold pipe" is supposed to mount for the P/S, so not sure which size bolts to pickup. I'm sure once I start digging around it will make sense.
I also went to throw the new pads in there today.... *sigh* turns out when I pulled the old pads, two of the calipers were leaking
Guess what I did today? Let's just say that thank goodness my brother Carter was here to watch my kiddo for a couple hours, and no, I don't really like re-building calipers.
Either way, not sure if it was the new tires, or the new pads, or the fact that some of the brake fluid spilled onto the pads/calipers/rotors, but bedding the pads was a smoky ordeal for the first 2-3 stops LOL!! Smoke went away, and pedal feel got a lot better after a handful of stops, so we're good on this front.
Also discovered that one of the wheels is fairly bent as well... *sigh* it holds air just fine, and I've spent too much money lately, so I'm going to hold off on replacing it for now, but just another thing to add to the list. The previous owner really didn't take very good care of this car, lol. Oh well.
I also happened to stop by RPM Motorsports in Lakewood, talked to Matt and picked up a new helmet.
Overall, I'm almost ready to run! Just have to put the P/S setup back in the car, change a few fluids, and get an alignment.
Although, there's a guy over in Erie, CO that has a 99+ torsen LSD with 4.30 FD, that is willing to swap me for my 4.10 94-97 LSD, so I might do that as well (might as well get back my OEM final drive ratio/get a bit more torque multiplication, as this car needs it haha!).
Slowly, but surely... she's getting there.
-Brandon
