speedjunkie wrote:Oh, I forgot to mention, I guess I'll be adding airjacks to my car...I stopped by the auto hobby shop after work yesterday to use one of their lifts...I can't even swing the arms under my car, it's too low LOL. Or I'll just have to use Frank's every time haha. His is the only one I can drive up on without taking the bumper off haha.
That was a big reason I got my own. I had to jack up my car in order to put the swing arms under my car! You're always welcome to use it.
iani1.1 wrote:Welcome to my world lol
I wouldn't say I'm QUITE to your world yet, I don't yet have to take off any body panels or bumpers just to be able to get the first/lowest jack under my car LOL.
PXRdriFT wrote:That was a big reason I got my own. I had to jack up my car in order to put the swing arms under my car! You're always welcome to use it.
So I can get a key to the house then? LOL
I knew someone would mention that. I'll have you know I did a search on google and that thread came up. I would never browse such a blasphemous site LOL.
Right now I have to use my stock jack to get the car up a bit, then use a normal jack. When I was home on leave I used a truck jack and I couldn't believe it fit under the car and lifted it with no issues, not even touching the sideskirts. Although that was with the other wheels and tires making it taller.
- yoojeankim
- Twisted_grip
I haven't worked on it since Tuesday so I'm not sure. I'm going to load an old map into the PFC and see if it starts. It started with a tow start and ran fine, so I'm thinking it might just be the map. But if that doesn't fix it and it still won't start, I think it might be the oil control rings bad already and it's not getting enough compression to start. Either way, it's still burning oil, so I'd have to still fix that problem too.
I won't make it to the cruise regardless. For one, I'm looking for more of I a spirited drive through the mountains and it seems that's not the point of this cruise.
I uploaded an old map and it fired up, but it still seems like something isn't right. He adjusted the crap out of my throttle body, which kinda ticks me off since I had it set right. So I'm trying to fix all that stuff since it's not idling right still and it idled fine before I went up there. Working on it now actually.
So the tune I made worked on it? Was he adjusted your air bleed or dashpot? Dashpot shouldn't effect starting but the air bleed will.
After looking at the tune I definitely think the split timing was rather aggressive (more than I would run), and the leading timing was a little sloppy, almost like a modified version of the PFC base map.
But your motor was still burning oil before the dyno so I still think you other issues (i.e. oil control rings or massive blow by).
Well I messed around with the map even after you messed with it, but yeah, pretty much that same map worked for a bit. I adjusted the air bleed screw again (yes, he adjusted it way out/open) and I tried backing off the idle screw on the front of the TB, back to just barely touching like it's supposed to be, because he had it turned in quite a few threads. I had it idling pretty well around 1150-1250 and after a while it started dying regardless of what idle was set to.
I know I have other issues with the burning oil, but I'd at least like to get this idle and starting thing figured out. As long as it doesn't have anything to do with bad oil control rings or something like that anyway.
Users browsing this forum: No registered users and 102 guests
eric i envy you
