My New Toy
Just finished installing some parts. I installed the vent, arm rest pad, steering wheel, sunroof crank, and the K&N filter.
iani1.1 wrote:awesome. i just did a full tune up to mine last week. except the fuel filter which ill do tomorrow or something. it runs soo much better that i dont really have to pull the choke every morning lol
Did you get all the parts you got from me installed?
Thanks to ecam8000 for all the help.
I got everything on the motor back together at about 6pm last night. I tried to start the car but was having trouble getting the fuel pump to prime. Today I'm going to install the new fuel filters, shark plug wires, and muffler. I will also do the tranny mount and drive shaft if I have time.
My rebuilt injectors:
They flow well one is 692 cc/min and the other is 702 cc/min at 43.5psi.
Well, is it running yet?
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
2 Fords 29 & 2000.
99 BMW 328i
The car is now running. It actually started right up this morning. I think it just needed a rest after yesterday, lol.
I replace the spark plug wires and installed battery hold down this morning. I also got the muffler replaced. The muffler was a complete nightmare. The two bolts that attached the muffler to the midpipe were completely rusted on and I had to use a cutoff wheel on them.
Next on my list is the fuel filters.
So it is ready for DD duty again?
Eric
2 Fords 29 & 2000.
99 BMW 328i
2 Fords 29 & 2000.
99 BMW 328i
Yup it seems to be doing good. I need to adjust the idle, mixture, and TPS a little but otherwise it seems to be doing good.
Yes I replaced the filters. I figured since I was replacing the injectors it would be a good time to replace the filters. I have one between the tank and the pump and the stock one after the pump.
The car has been running good. I seems to be getting better mileage and doesn't smoke at startup.
I worked on the car on saturday. I replaced the last coolant hose that needed replacing.
I'm very happy with onlinemazdaparts.com. They sent the wrong hose (it had the right parts number but was bagged wrong) so I called them to get it right. They sent a new one right away with a return slip for the old one, no questions asked.
I also did some more cleaning under the hood. I pulled the battery tray and painted it. I cleaned a bunch more grease off the motor.
Here is the newest pic of the motor:
