Mazdaspeed6
cprtrainer
Postby cprtrainer » Thu May 14, 2009 9:14
3.2 (3 is fine) qts MT90 for transmission
1 qt 75/90 for the diff.
I have not done the transfer case-- as mine was replaced by Mazda when I had the clutch TSB done recently.
They are all pretty easy- the T-case has a slightly difficult to reach fill bolt.
I'll update more this weekend if I am able to get under there as planned.
Derek
Benji1989
Postby Benji1989 » Fri May 15, 2009 9:14
Awesome! If you know where the fill/drain holes are on the tranny and diff case that would very helpful as well. Thank you!
Conyezzy
Junior Member
Postby Conyezzy » Mon Dec 27, 2010 9:14
Hey man, i was just browsing around and found this mazda club thing. lets go out and ride, i have the same ms6 as you
LaginWagon
Postby LaginWagon » Thu Dec 30, 2010 9:14
This thread is over a year and a half old. Good job...
Postby ~Barn~ » Thu Dec 30, 2010 9:14
Better late, than never.
Image 720.935.6438
Postby tbot » Thu Dec 30, 2010 9:14
Of all the threads to post in too...wow...just wow
Postby bellalyssa » Thu Dec 30, 2010 9:14
I drained my transmission fluid a few months ago and boy was it time. I'm guessing mine hadn't been done for awhile because after putting the MT90 in my car shifted so much smoother.
LaginWagon
~Barn~ wrote:Better late, than never.
True, true...
Postby RX-7 Chris » Fri Dec 31, 2010 9:14
you guys sound like some of the people on the other forums.
Postby kingtut » Sat Jan 01, 2011 9:14
RX-7 Chris wrote:you guys sound like some of the people on the other forums.
Other forums? There's other forums? Fuuu
(leaves in search of "other forums"...)
chromal
Postby chromal » Sat Jan 01, 2011 9:14
bellalyssa wrote:I drained my transmission fluid a few months ago and boy was it time. I'm guessing mine hadn't been done for awhile because after putting the MT90 in my car shifted so much smoother.
I've been thinking about the MZ3 MTF change interval lately. You won't find any info on a suggested change interval in either the '10 owner's manual OR the '10 service manual. Any idea how many miles were put on with the MTF you drained and replaced? Any discoloration in the old stuff?
Postby Number2 » Sun Jan 02, 2011 9:14
That's what she said
RichB
Postby RichB » Tue Jan 04, 2011 9:14
chromal wrote:I've been thinking about the MZ3 MTF change interval lately. You won't find any info on a suggested change interval in either the '10 owner's manual OR the '10 service manual. Any idea how many miles were put on with the MTF you drained and replaced? Any discoloration in the old stuff?
I change my fluid every 30K. I do it at that interval partly because I use MT90 and put a little friction modifier to make a LSD quieter. The modifier breaks down the fluid faster, so I change it sooner rather than later. Without the modifier I'd probably leave it in a little longer.
On how the old fluid looks, I have never had any discoloration. It always looked pretty clean and clear.
