Great -- Another Problem
Postby bellalyssa » Mon Oct 04, 2010 9:14
I have a TSB out for that damn purge valve and they won't fix it for free at the dealership. It's a known problem with 2004 Mazda3's and they won't do a damn thing about it since I'm not under warranty. I'm not surprised Chris can't get his TSB fixed b/c of my issue with Mazda.
PXRdriFT
Postby PXRdriFT » Mon Oct 04, 2010 9:14
I guess the question is whether or not he has a case if the TSB came out while he was under warranty and it wasn't fixed. Ususally when I take my car in for service, they let me know about any TSB that are out on my car and schedule the repair. It looks like this may have been missed by Mazda and could use it as potential leverage in getting them to repair. It couldn't hurt to try.
Renesis Rx
Postby Renesis Rx » Mon Oct 04, 2010 9:14
Yep. Service Deps. are supposed to check for recalls and TSBs when your car is in. If there is one while your car is under warranty and it compromises saftey and or proper operation of your car then it is supposed to be fixed.
Renesis...MMMMMMMMM
Postby Stealth01 » Mon Oct 04, 2010 9:14
Well this one says SPECIFICALLY that it is only to be applied IF the customer complains of symptoms while under warranty.
Postby tbot » Mon Oct 04, 2010 9:14
Here's the actual TSB.
[The extension pdf has been deactivated and can no longer be displayed.]
Renesis Rx
Oh damn...that sucks man.
Renesis...MMMMMMMMM
Yep, but oh well. $250 isn't the end of the world. And I'm still not 100% certain it's the timing chain sound -- just sounds different. And check this:
If the car sits all night, and it gets cold, it'll make the sound on startup. Or if I let it sit in the shade of my garage all day. But when it sits in the sun at work fro 8 hours and I start it, there's no noise. The timing chain should NOT be affected by sitting in the sun. That said, I don't know WHAT it is, but I'm leaning away from the chain. Maybe wishful thinking lol.
Its not the timing chain Chris, its the VVT actuator slapping against itself due to a pin being bent/broken. The VVT itself works off oil pressure iirc, so with that actuator pin being broken there isn't the pressure build up required to keep it from slapping around.
tbot wrote:Its not the timing chain Chris, its the VVT actuator slapping against itself due to a pin being bent/broken. The VVT itself works off oil pressure iirc, so with that actuator pin being broken there isn't the pressure build up required to keep it from slapping around.
So shouldn't it be consistent on startup after a few hours shut down? I still wouldn't think the sun would have much effect on it...
Is this the same issue as the video below?
[ame="http://www.youtube.com/watch?v=yV6AXcAhotM"]YouTube - MS3 VVT malfunction[/ame]
Renesis Rx
This might be WAAAAAY out there but if it's the prob the TSB says it's the VVT lock pin like Tbot said. And it says they use heat treatment to stop it from happening. Maybe sitting in the sun is like a mini dose of heat treatment for it. Again, kinda out there but not improbable. Only way I can explain the inconsistency.
Renesis...MMMMMMMMM
yep...cept mine lasts longer lol...but same thing
Thats what the heat treatment is for...to avoid the "extreme" expansion and contraction of temperature swings on metal, so that could be the reason as well.
Just face it Chris, this is the problem with your car.
tbot wrote:yep...cept mine lasts longer lol...but same thing
Well, that's not what mine sounds like. And mine is easier to hear from inside the cabin than outside.
Doesn't mean it isn't the problem, but I'm not worried about it right now. If it gets worse and starts to sound like that video, then I'll worry.
What I'm talking about is in this video. It's at the VERY end, after shut down. You'll see the power steering fluid reservoir shake...it's the sound that happens at the same time as that movement.
That said, listening to that video and one other I took from farther back, I may ALSO have the VVT actuator sound. LOL. Double fail.
Oh well. I'll just plan to have it done before the warranty expires in April. $250 isn't going to kill us. We just caught a HUGE break on our roof, so things are looking up.
uh....hmmm
hard to say...sounds kinda like valves...
and was there smoke coming out of the back of the engine bay towards the left of the video?!
at the same time tho, the shutdown sound ur talking about happens in my car as well, and i dont think i've ever given it any thought at all. its probably just something outside (power steering resevoire) shaking and hitting something.
