New from the western slope with an FB
BRC
Postby BRC » Mon Jun 15, 2009 9:14
welcome! always good to have another RX on the forum!
Daddy
Postby Daddy » Tue Jun 16, 2009 9:14
Thanks for the welcome!
The parts car got delivered yesterday afternoon!
234,xxx miles!
Started moving a few little things over
Before
After
Before
After
Postby RX-7 Chris » Tue Jun 16, 2009 9:14
wow that car has a nice dent.
I may be interested in the front fenders, the header panel, and headlight covers if they are free of dents and rust and the price is right.
Daddy
RX-7 Chris wrote:wow that car has a nice dent.
I was thinking of swapping over the fenders but i want to look closely at the gray fenders because i think the only problem with them is one of the mounting tabs is bent up and i think i can fix that so i may not have to swap the burgundy ones.
I'll let you know about the other parts and can get some pictures if i decide i don't need them.
Daddy
BTW am i right the only way to tell if it for sure has LSD and not just a disc conversion is to open up the diff?
It looks to be a GSL car because it has cruse, P/W. to convert the car to disk they would have had to change out the whole rear because the housings are different. the way to find out if it has LSD is jack the rear up and turn the wheels, if they both go the same way then then it has a LSD, if they go opposite directions then it is open.
Daddy
Thanks man. I kinda thought it was the GSL. i'm still fairly new to the FB though. i've only owned one since January. The gray one is a GSL as well.
If you know someone who would want the rear axle then it'll probably be for sale when the time comes.
Return to “New Member Forum”
