ATP GT Series Turbo Kit - Mazdaspeed6
Postby SpeedRacer » Thu Dec 25, 2008 9:14
GT3071R Bolt-on Turbo Kit with 100% of hardware components including but not exclusive to, Garrett ball bearing turbo with ATP proprietary exhaust housing, high pressure internal wastegate assembly, V-band output module, 3? Stainless downpipe, 3? inlet pipe set, fittings and fasteners. Turbo is efficient up to 22 psi on the MS6 2.3L turbo engine and can produce 450 crank HP as configured with supporting mods and proper tuning. Uses stock exhaust manifold and very easy to install. The GT3071R is absolutely the best spooling turbo on the market capable of making 450HP. Highly recommended for a very broad powerband with a lot of "area under the curve".
Comes with Catted downpipe.
$2500.00
Roadrnr06
Postby Roadrnr06 » Tue Feb 03, 2009 9:14
Bump^^
[/SIZE][/font]
