MS3/6 Parts (For real this time)
Postby erod550 » Fri Jan 28, 2011 9:14
Cool Dange, let me know. I'm pretty sure I still have the extra tubing and fitting that I used to hook up to the cold pipe for the boost source for the Synapse that I can include too.
rmeeker13
Postby rmeeker13 » Fri Jan 28, 2011 9:14
erod550 wrote:Meeker, I'm sorry about the SRI. Someone else PM'd me basically at the same time as you with interest in both it and the Inlet. And as for the mount, almost everyone installs both sides at the same time. I don't want to be stuck with just a passenger side mount that nobody wants by itself because it's rare that people install just one side.
Batman, I do still have the TMIC available.
Its cool man...I just like to talk shit!:)
I found one on msf for just a bit more!
Postby bellalyssa » Fri Jan 28, 2011 9:14
I have the other two mounts. SU was out of the Transmission mount when I ordered the Rear and Passenger side mount. I'd like to have a complete set. Just let me know if you want to split them up.
Dange
Postby Dange » Sat Jan 29, 2011 9:14
Awesome yeah chris was worried if it had all the tubing. Fittings etc. included for the install
04MSMGT
Postby erod550 » Sat Jan 29, 2011 9:14
Yea I still have all that I'm pretty sure. I'll have to dig through my box of crap and make sure. I had to get some T fittings and extra vacuum hose because you can't just hook up the stock line to it since the stock vacuum line is ginormous compared to the fittings on the Synapse.
Postby erod550 » Thu Feb 03, 2011 9:14
Prices reduced on a couple things.
Postby erod550 » Sun Feb 13, 2011 9:14
Reduced prices on stuff and the intake is available again.
Postby erod550 » Sat Feb 19, 2011 9:14
So nobody needs an intake or BPV?
Postby erod550 » Wed Feb 23, 2011 9:14
Intake sold. Price dropped on the BPV and cold pipe.
reconbygod12
Postby reconbygod12 » Wed Feb 23, 2011 9:14
what does a cold pipe even do i never researched it is it even something i need on my car
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Postby erod550 » Thu Feb 24, 2011 9:14
The cold pipe is the pipe that connects the TMIC to the throttle body/intake manifold. It's also the stock location for the BPV. All DISI cars come with one, though the one for the '06 MS6 is different I believe. This one is just drilled/tapped so you can hook up water/methanol injection or use it for an extra boost source for your BPV if it needs it, which the Synapse does. If you're running a front mount intercooler, you would not need it and would have removed your original one.
reconbygod12
Postby reconbygod12 » Thu Feb 24, 2011 9:14
that clears it up then but i sent you a txt from 920 for the dash to meet up
04 mazda 6s-gone
Postby erod550 » Mon Feb 28, 2011 9:14
Rock bottom price - $125 for the BPV and cold pipe together. I need this thing gone!
reconbygod12
Postby reconbygod12 » Mon Feb 28, 2011 9:14
do you have mazdaspeed flange on or just the bpv because my buddy is looking for a bpv
04 mazda 6s-gone
It has the Mazdaspeed flange and also another universal one that you could weld into a pipe. You could use it with either one.
